Tire Sizing Advice
Old 08-05-09, 01:39 PM
IcEnPinKi
IcEnPinKi's Avatar
Default Tire Sizing Advice
Hey everyone..Im looking for tires in the size 225-30-20..I have a 8-8.5 wide rims on the front and want a slight stretch on it so I can get it my car to sit a little lower. Can anyone tell me a decent tire with a heavy load rating that they have used and can recommend? Any input much appreciated. Thanks!
Old 08-08-09, 06:44 PM
05ES330
05ES330's Avatar
hey didn't you use to have an es300/es330?? 225 on an 8.5 causes a slight stretch. im running 225s on 20x8.5 +15 right now. going to switch to 20x10
Old 08-13-09, 11:34 AM
IcEnPinKi
IcEnPinKi's Avatar
yes i used to have an ES and traded it for the SC430. So much more fun with this SC..I know its not alot of tire by running on a 225 but have you had alot of problems?
Old 08-13-09, 05:58 PM
lovely09
lovely09's Avatar
I like SC perfect for Lexus because of its feature a Direct Tire Pressure Monitor System.When tire pressure is critically low,the tire pressure sensor in the valve stem which is linked to the SC's computer alerts you immediately with a light on the instrument panel.The warning light will blink to alert you in the event of a system malfunction.
Old 08-14-09, 10:39 PM
05ES330
05ES330's Avatar
225/35 worked well for me. its only a slight stretch. 225/30 might be a bit too small for an SC and not be able to fill the wheel well gap to well. I just test fitted 20x10 with 245/35/20, and those tires a really stretched. they are not drifter style stretch, but there is a bit of the lip exposed
Interapid
ES - 6th Gen (2013-2018)
22
07-31-18 04:22 AM
verly6565
05-19-14 04:32 PM
mantastic
06-25-12 10:45 AM
uae
03-10-08 09:16 AM
mjr24
09-10-03 05:53 AM
Quick Reply: Tire Sizing Advice
