tire speed rating
Old 07-02-09, 12:04 PM
phat167
phat167's Avatar
Default tire speed rating
irecently blew a rear tire on my g37, when i bought a new one i bought the 245/40/19 94Y i noticed that the oem one is 94W , is this a concern mixing rear speed rating? since iam not downgrading the speed rating? btw the tires are exactly the same except for the different speed rating
THanks for the help
Old 07-03-09, 11:33 AM
Sltwtrking
Sltwtrking's Avatar
It's best to have the same speed rating all the way around and at least two of the same speed rated tires on the same axel. Lower speed rated tires (when replaced in pairs) should be put on the front axel regardless of drive axel to help prevent oversteer. However, the Y and W are both Z rated speed ratings so you should be alright. Technically, you upgraded the speed rating from OE which is fine. Keep in mind, the speed rating for all the tires will be that of the lowest speed rated tire on the vehicle. In this case 168mph.
Boomin
06-18-18 01:05 PM
Billb1332
11-28-15 04:53 PM
kanklez
07-25-12 10:37 AM
mdv
RX - 3rd Gen (2010-2015)
14
06-09-10 07:25 PM
Quick Reply: tire speed rating
