stock GS 17's
stock GS 17's
Hey all, does anybody know how much stock 17" GS wheels weigh? I am trying to figure out how they may compare with other aftermarket 17's or maybe even lightweight 18's.
20lb savings on your car
Originally posted by gs4power
23 lbs. I measured it myself.
You're welcome... Yes, it is feasible to have a bigger but lighter and stronger wheel....the secret is Forging.
Forging makes the material much stronger... and the wheel can use less material.
I saved about 40 lbs overall with the TE37/Toyo setup (Toyos T1-S are the lightest tires in its class) compared to the stock 17" setup...
Thanks for the info on the tires too!! So you are saying that your tires are 20 lbs lighter than stock, and that your rims are 20lbs lighter than stock or that your tires alone give you 40lb weight savings over stock tires?
Thanks!!!
No...wheels about 26 lbs lighter and tires around 12 lbs lighter.
gs4power,
Thanks for clarifying that. Now I know what I must do when I get my GS That would drop the 98-00' GS400 curb weight from 3693 to 3655lbs, the same as the 98-00' SC400's.GREAT
Thanks gs4power
Let's all give gs4power a round of applause from our seats for showing us how to save 40lbs over stock GS curb weight and looking better at the same time.:eek:
Re: Thanks gs4power
(gets up) *CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP CLAP* (sits back down)
You guys crack me up...Thanks for the standing ovation...
ARB, you are actually saving more than you think. The mass of the wheels/tires is not equivalent to the weight of the other components in the car. This is because the wheels/tires rotate. You need about twice the energy to rotate the wheel than just to move it straight....the rule of thumb is that for every pound you save on wheels, is like saving three times as much weight elsewhere. 40 lbs saved in wheels/tires will have the same effect as 120 lbs less curb weight, in acceleration and braking.
Wald GS
Wheels, Tires & Brakes Forum
06-02-04 07:58 PM
