Tires Suggestion for IS350 (Tenzo R GF-7 19x8 Front and 19x10 Rear)
Old 03-26-09, 10:15 PM
BLK IS350
BLK IS350's Avatar
Default Tires Suggestion for IS350 (Tenzo R GF-7 19x8 Front and 19x10 Rear)
Sorry Guys this is my second attempt. The first time the post didn't show up correctly.
I have a 2006 Black IS350 and need help in selecting the correct tires. My car is currently not drop but planning to in the future. Probably Eibach springs or Tein Springs.
Here is the description of the rims PLEASE let me know the best option as far as looks goes and the way it rides.
Tenzo R GF-7 (Hyper Black)
Front:
Bolt Pattern: 5x4.5/114.3 – 5x120
Offset: 45
Rear:
Size 19x10
Offset: 45
Please let me know what tires is the best for this setup. Thanks
Attached Thumbnails Tires Suggestion for IS350 (Tenzo R GF-7 19x8 Front and 19x10 Rear)-tenzo-r-gf-7.jpg
Old 03-27-09, 12:34 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I have to point out one thing about the wheels you have chosen, as many people don't realize until they have them sitting in front of them...
they are dual drilled wheels right? so, that means instead of 5 clean lug holes, you get 10 lug holes of two different diameters... one set won't be used...
I realize the Tenzo R stuff isn't exactly top end stuff, but there are plenty of inexpensive wheels out there with covered lugs, or, exposed lugs with just one set of holes for them...
Its just my opinion that the extra set of lug holes cheapens the look of the wheel significantly, regardless of what it looks like otherwise...
Old 03-27-09, 01:01 AM
XhyDra
XhyDra's Avatar
Nitto Invo's nuff said
Old 03-27-09, 11:57 AM
BLK IS350
BLK IS350's Avatar
Thank you for your opinion. I some what agree with you. But I need suggestion as to WHAT SIZE TIRES I SHOULD USE!!!
Thanks
Old 03-27-09, 12:13 PM
mitsuguy
mitsuguy's Avatar
245/30-19 front 275/30-19 rear...
275/30-19 rear nets 25.5" diameter stock is 26"
245/30-19 front nets 24.7" diameter stock is 25.1"
these would work just fine, both being a touch shorter than stock, but it would keep the ratio front to rear in check and would be a pretty wide setup...
you could also do (these would be closest to stock diameter, but kinda narrow for your wheels)
225/35-19 front 25" diameter
255/35-19 rear 26" diameter
and one final option (a little larger diameter than stock, but not a huge amount and still maintains proper ratio front to rear)
235/35-19 front 25.5" diameter
265/35-19 rear 26.3" diameter
Old 03-27-09, 12:19 PM
sleeper408
sleeper408's Avatar
With conservative offsets like those, you could even possibly run a fat tire set up as well.
Old 03-27-09, 01:40 PM
BLK IS350
BLK IS350's Avatar
mitsuguy,
Thank you so much. Thats exactly what im looking for.... do you know if anyone of those setup is best used when car is drop about 1.5".
I know I have to roll the fender but I don't want it to look stupid. Please Advise
Old 03-28-09, 05:57 AM
mitsuguy
mitsuguy's Avatar
Larger diameter tires are typically not advised when you plan on lowering the car... I would pick one of the first two (245/275 or 225/255)... the 225/255 setup will probably not require rolling the fenders, 245/275 will be close... I personally like wide tires, so I'd do the 245/275 if it were my car...
Old 03-29-09, 06:38 AM
GS2006
GS2006's Avatar
The holes open sure would look like crap. Just curious though, don’t they provide false lug nuts to cover up the unused holes? I would think that would look okay as long as the offset is not different to go with the different diameter??
Thanks for pointing it out though, I would not notice from the picture. They hide it well
abitta1
08-30-12 04:00 PM
2slow
12-01-09 12:56 AM
mitsuguy
03-23-09 05:26 AM
AZ06IS350
Suspension and Brakes
14
07-06-08 05:36 PM
PhilipMSPT
11-26-05 08:08 AM
Quick Reply: Tires Suggestion for IS350 (Tenzo R GF-7 19x8 Front and 19x10 Rear)
