is 225/50/16 and 205/55/16 same sidewall?
Old 03-20-09, 12:58 PM
rule1223
rule1223's Avatar
Default is 225/50/16 and 205/55/16 same sidewall?
hi guys, i don't know anything about tires and wheel, wanna ask a question here.
i have a Canadian base model 2is that comes with 205/55/16 tires, i m not going to get bigger size rims but i would like to go for some wider tires. my question is
will 225/50/16 make the car lower? or same as stock? any negative effect on the car? pls help thanks.
Old 03-20-09, 01:34 PM
sleeper408
sleeper408's Avatar
225/50 = 112.5 mm sidewall height
205/55 = 112.75 mm sidewall height
They are almost identical. This will not make the car any noticeably lower. What is the width of the wheel though? You may not have that extra protection from curbs and such. Is there any reason for going from a 225 to 205? If the factory recommendation is 225/50, I would just stick with that.
Old 03-20-09, 01:57 PM
rule1223
rule1223's Avatar
no, no im going from 205 to 225. but thanks for the info bro!
Old 03-20-09, 01:58 PM
rule1223
rule1223's Avatar
i think the width is 7"
Old 03-20-09, 08:25 PM
sleeper408
sleeper408's Avatar
Oh...sorry about that. I misread your thread. In that case, you should benefit from the extra sidewall and 20mm of width. Should help protect against curbing and potholes. Good luck!
Old 03-21-09, 07:05 AM
rule1223
rule1223's Avatar
thanks bro.
ThumperPup
11-28-15 06:37 PM
sc300gte
04-06-07 04:51 AM
oayodeji
13
09-09-04 11:06 AM
BkLexZ
08-07-03 12:48 AM
Quick Reply: is 225/50/16 and 205/55/16 same sidewall?
