Installing new shoes
Old 03-16-09, 11:30 PM
UncleRay
UncleRay's Avatar
Default Installing new shoes
Tried to install some new rims today, ran into a problem. The sockets for the lug nuts are a bit too narrow for my oem wrench to fit inside. I can hand tight them, however, the tire is still loose. Anyone have any ideas?
Old 03-16-09, 11:40 PM
japspec
japspec's Avatar
Take a pic of the lugs if i have a spare lug key ill send it to you until you can get the right wrench for it.
Old 03-16-09, 11:43 PM
UncleRay
UncleRay's Avatar
Is it like an extension or something?
New specs on lugs are 12x1.50
Old 03-17-09, 12:09 AM
[ant]
[ant]'s Avatar
i am struggling to understand what you're asking? the sockets for the lug nuts are too narrow for oem wrench to fit inside? wtf?
do you mean you cant get your oem wrench onto the lug nut to tighten it once it is inside the mag wheel? ive never had an issue i just use my socket set which has different sized socket and i find the one that fits in the hole and onto the lug and tighten it..
Old 03-17-09, 12:23 AM
UncleRay
UncleRay's Avatar
You know the holes for the lug nuts? Mine are too narrow on my 20" rims. Lug nut pattern is 12x1.50... which is MUCH smaller than original, ergo, I can't fit the wrench in there... If you don't understand... search.
Old 03-17-09, 12:42 AM
Clear2Cloz
Clear2Cloz's Avatar
use a ratchet with an extension
Old 03-17-09, 12:51 AM
VipDout
19x11.5 -51
VipDout's Avatar
^ +1 ................
Old 03-17-09, 07:06 AM
Debonair
iModerate
Debonair's Avatar
Get a thin wall socket. I used the aluminum kind that come with the poly sleeve on it. I had to pull the sleeve off to make it fit.
Old 03-17-09, 07:08 AM
GS300ToM
GS300ToM's Avatar
wont hurt to use a extension and a ratchet
Old 03-17-09, 07:09 AM
junjdm
junjdm's Avatar
becareful not to strip it....that will be no fun.....
Old 03-17-09, 07:26 AM
carbongs
carbongs's Avatar
sounds like to me you need a tuner lug wrench. are you going from stock wheels to aftermarket or from aftermarket to newer aftermarket?
Old 03-17-09, 08:18 AM
UncleRay
UncleRay's Avatar
Stock wheels to aftermarket Carbon. Where can I purchase a tuner lug wrench?
Old 03-17-09, 08:29 AM
AZDesertGS
AZDesertGS's Avatar
They should have come with the tuner lugs you bought. I have a spare one but that won't do you any good since you need to tighten them now
It will look like this below....
Old 03-17-09, 09:05 AM
excluesive
excluesive's Avatar
just use a regular deep socket with a ratchet
Old 03-17-09, 10:05 AM
Debonair
iModerate
Debonair's Avatar
This is correct assuming he is using lugs that require a special socket. If he is using regular lugs and the socket does not fit he will need to get a thin wall socket OR tuner lugs that use a smaller socket OR special tuner lugs like you have pictured that include their own socket.
What do you actually have OP? Pics?
Quick Reply: Installing new shoes
