Will tpms work with these size tires
Old 03-07-09, 03:27 PM
iron_lungs
iron_lungs's Avatar
Default Will tpms work with these size tires
Will the TPMS from my stock 3GS wheels work on a set of aftermarket staggered tires as below:
245/35/20 Fronts
275/30/20 Rears
Thanks guys.
Old 03-07-09, 11:33 PM
steviej
steviej's Avatar
depends on the whether or not the rims you plan to use can accept Pacific brand TPMS sensors. Your best bet is to contact the manufacturer of the rims you plan to use and check with them. If the rim will accept the sensors, then you shouldn't have a problem.
You will just have to re-initialize the system when you mount them up.
steviej
Old 03-08-09, 05:10 PM
retrospexo
retrospexo's Avatar
stevie, how do you re-initialize the system after mounting?
depot90
RX - 4th Gen (2016-2022)
12
05-08-17 10:23 AM
sjgIS350
07-11-16 10:52 AM
UnderCover
02-01-16 04:26 AM
iron_lungs
08-30-08 01:45 PM
LAMPRO
11-28-07 01:05 PM
Quick Reply: Will tpms work with these size tires
