question about is300 rims
Old 01-30-09, 04:27 PM
BostonVP
BostonVP's Avatar
Default question about is300 rims
well, im planning to get a 2001 lexus gs300, and i was wondering if i would of took out the gs300 both rim and tire, put the is300 both rim and tire in, will it drive fine? and problems with the installion? if so, what should i do to figure out whats the best way to put is300 rims on 01 gs300.
Thanks,
Le
Old 01-30-09, 05:17 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
You should be okay, the only difference is that the OEM IS300 wheels are narrower than the OEM GS wheels. I think it's 7.5" for the IS wheel and 8" for the GS wheel.
Actually, someone here on CL ran this set-up on their car. If you'd like to see a picture, visit the thread below
https://www.clublexus.com/forums/gs-...n-a-gs300.html
Old 01-30-09, 05:35 PM
rominl
exclusive matchup
rominl's Avatar
is300 wheels will work on the 2gs
Old 01-30-09, 05:36 PM
rominl
exclusive matchup
rominl's Avatar
are the 16" wheels on the 2gs also 8" wide?
Old 02-02-09, 01:42 AM
BostonVP
BostonVP's Avatar
Aite, thanks guy, will update you guys further more with the car.
Old 02-02-09, 06:41 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
wheels no problem, tires problem... tire is about an inch shorter, off top of my head...
Ckaler
03-25-08 07:25 PM
Carpe Diem
06-18-03 03:04 PM
IndyGS3
05-23-02 09:42 AM
fierce gs
09-26-01 09:28 AM
Quick Reply: question about is300 rims
