255/55R16 vs 215/60R16
225/55R16 vs 215/60R16
Earlier SC's had 215/60R16 tires, but at some point 225/55R16 became standard.
There is a very slight difference in width and height (less than ¼"), but is there any significant difference in performance or feel between these two sizes?
Thanks,
Harpo
Thanks,
Harpo
I've been looking into switch from recommended size for ride comfort myself (to go from 245/40/18 to 245/45/18).
While I can't specifically provide an opinion on your question, I can say that the difference between 255 (~10") and 215 (~8.45") is more than what I'd think is considered "slight" in terms of tires, and the side height difference is close to a half inch (not less than a quarter).
I'd question whether there is a safe 1 1/2 inch width range for tires on the same rim. I'm not saying there isn't, just that would be a question I'd have.
Zombie Slayer
255 was never a standard size if you are referring to 1st gen SC's. 225/55/16 is the standard.
The slight difference is tiny when comparing daily driver all-season tires. The real deciding factor would be the tire compound over width alone.
