wheels question
Old 11-26-08, 09:49 AM
Rockero28
Rockero28's Avatar
Exclamation wheels question
Is it possible to have OEM Toyota wheels widened? I have heard this before, but I want to know if it is possible, and recommended. I know you can add spacers, but just not sure I want to add a wheel spacer to the front due to the stress. Anyone have wheel spacers up front of say 25mm and if you do, what is your experience??
Thanks,
Rock
Old 11-26-08, 09:54 AM
RI-Lex
RI-Lex's Avatar
I wonder about the stress issue too, since I've been playing with the idea to add 15mm to the front.
Old 11-26-08, 10:41 AM
Rockero28
Rockero28's Avatar
Default wheels
I was told by a perf shop that adding a 15mm would not be too bad, but best to add a 5 or 10 and no longer studs would be required. But I am not sold on how safe that would be since they are at a much higher stress than the rear wheels.... especially if you hit a pot hole or run over something... Where are all the wheel gurus?? Help!!
Old 11-27-08, 07:23 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
anytime you re engineer a car, you put more stress on wheel bearings, ball joints, etc...
also, obviously, wheel studs and such... if ever can be avoided, I would definitely not use spacers... too many variables...
as far as widening a wheel, I've seen it done once, but, same thing, your safety is left up to a welder to do a good job...
uchujin
09-29-19 11:04 AM
occxlr8ed
IS F (2008-2014)
37
07-31-14 10:41 AM
Codfish
Suspension and Brakes
11-07-10 01:50 AM
lexi4darin
08-28-07 08:37 AM
sleepybobcat
RX - 1st Gen (1999-2003)
05-14-01 07:35 AM
Quick Reply: wheels question
