larger diameter wheel = more negative camber on lowered car?
Old 09-18-08, 03:13 PM
Phamboogie
Phamboogie's Avatar
Exclamation larger diameter wheel = more negative camber on lowered car?
So I may have a buyer for my wheels and I may get his stockers as a trade. Now my question is: (assuming the transaction works out) since the wheels I will receive will be smaller in diameter (16s), would my (negative) camber be reduced resulting in me getting closer to OEM specs? Currently I'm -2.7° on one side and -2.8° on the other in the rears. I'm rolling on 20s.
I'm wondering if I should bother adding the front and rear RCAs if I'm going to mount 16s/17s onto my lowered car.
This is how my car is currently sitting on 20s:
Thanks!
Old 09-18-08, 06:24 PM
[ant]
[ant]'s Avatar
what are the tyre specs for each? this will determine the rolling diameter and will decide whether it will make a difference
Old 09-19-08, 06:00 AM
Phamboogie
Phamboogie's Avatar
Stock tires will be high-profile tires that are within OEM spec.
Old 09-20-08, 12:46 AM
CK6Speed
Super Moderator
CK6Speed's Avatar
Assuming you do nothing to your suspension and only change the wheels, it will have absolutely zero effect on your camber. Your camber will still be -2.7*.
PS. How did you get that degree symbol? My keyboard doesn't have anything like that
Old 09-20-08, 01:21 AM
PHML
Master Thread Closer!!
PHML's Avatar
Chris....good question
Old 09-20-08, 09:31 AM
milky
milky's Avatar
character map under system tools haha
Old 09-20-08, 09:04 PM
Phamboogie
Phamboogie's Avatar
I Googled it because I was too lazy to look it up in MS Word.
Alt + 0176
Thanks, again.
uchujin
09-07-18 03:15 PM
jorgie523
03-24-14 09:45 AM
ekrebs
Suspension and Brakes
01-15-09 06:51 AM
nihard
09-26-08 05:19 PM
Sundance
03-05-07 02:08 PM
Quick Reply: larger diameter wheel = more negative camber on lowered car?
