Need Advice On Tires
Old 02-14-02, 11:28 AM
markgs300
markgs300's Avatar
Default Need Advice On Tires
First its good to be back at this forum. I have no idea where it went but I'm glad I found it even thugh I had to re-register.
I have a '98 GS300 and I will probably be getting a new set of tires. What I would like to know is are there certain brands that may make the GS more comfortble or handle better (either/or) than the factory tires? I know this to be very true for my other car and in fcat, the factory tires for the Vette are POS's. Any help would be appreciated.
Oh, I have one other question. Has anyone test driven the 2002 ES? I'm curious as to how it compares (Handling and cornering) to the '98 GS? Intuition tells me that although they changed the ES, it doesn't compare to the older ('98) GS.
Old 02-15-02, 11:22 AM
GS4Will
GS4Will's Avatar
on the gs, 90% came with pos brigestones...so basically 80% of top name brands are much better....cheaper too assuming you have the 16s, consider these:
yoko avsdb
bridgestone re730
dunlop sp5000
toyo t1-s
take a look at www.tirerack.com for tons of user feedback
the ES is wayyy too soft of a ride, no sports sedan factor at all
Old 02-15-02, 11:53 AM
markgs300
markgs300's Avatar
yoko avsdb
bridgestone re730
dunlop sp5000
toyo t1-s
Those help, esecially the yoko. I'm familiar with Tirerack (who recommended the Dunlop) so I did reviews on the Yoko. Wow, the majority were impressed by the quietness of the tire. Many thought the RE730's were a bit noisy. I also thought about the Bridgestone Turanza REVO. The reviews on that wre some of the nest I've seen. I may choose between the Turanza and the Yoko's. I wonder why the Yoko's are so cheap though, when you compare them to the Bridgstones or the michellins?
Old 02-15-02, 12:21 PM
GS4Will
GS4Will's Avatar
actually the top of line yokos avs sport are quite expensive as well....the michellins acrosss the product line are simply more $$$...they are good tyres in general, but one certainly does not need to pay that kind of $$$ for tyres..btw, i think michellins soend much more $$ in ads, and some one has to pay for it...
Old 02-16-02, 03:00 AM
SandRock
SandRock's Avatar
Nitto-450 @ $88 a tire 225/55/16
Old 02-16-02, 04:29 PM
SandRock
SandRock's Avatar
How bout $84 with $34 shippin?
Old 02-16-02, 06:52 PM
Received 2,127 Likes on 1,379 Posts
Nitto's stink. Not smooth, not quiet, not good.
While the cost on some high end tires is inflated generally you get what you pay for.
Old 02-16-02, 06:59 PM
2SAVVY
2SAVVY's Avatar
Look at getting the Toyo T1-S.. Price wise its reasonable.. Easy to balance from what my tire guy tells me.. And they are an overall good buy!
Old 02-21-02, 02:02 AM
SandRock
SandRock's Avatar
What do you recommend?
Old 02-21-02, 06:04 AM
I switched to Toyo T1-S's. Nice tire, but bear in mind it's a DIRECTIONAL tread, and a high performance tire. If you don't drive/corner aggressively, there's no need to get this kind of tire.
Dunlop SP5000 I hear is smooth and quiet.
Perhaps Toyo's next less aggressive one, (FZ4?).
Michelins are always good, but expensive.
Old 02-21-02, 09:15 AM
TXSTYLE
TXSTYLE's Avatar
T1-S baby all the way!
jimv1983
ES - 6th Gen (2013-2018)
08-25-20 12:15 PM
amy8350250
04-01-19 07:19 AM
Blk04GS430
10-28-10 08:29 PM
njes300
08-12-04 12:57 PM
sniper5
03-14-02 12:41 PM
Quick Reply: Need Advice On Tires
