Nitrogen in Run Flats
Old 06-29-08, 09:43 AM
gbondioli
gbondioli's Avatar
Question Nitrogen in Run Flats
Is there any less advantage to using nitrogen over regular compressed air in run flats, compared to regular tires? I know the advantages of less alloy corrosion and adding air less often will be the same. But what about ride comfort? Handling? Would these be enhanced by nitrogen, since the sidewalls are so stiff, already?
Also, since I don't check tire pressure often, I'm thinking nitrogen would be a good idea for me. Any guess how much longer a set of tires will last me if I make the switch?
Old 07-01-08, 11:33 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
If you don't check your pressures often Nitrogen is probably a good idea, because it doesn't fluctuate with the ambient temperature as much as regular air.
Old 07-02-08, 06:13 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
so long as you check your air pressure, nitrogen is almost pointless...
it does not ride better, it will not make tires last longer (so long as proper inflation is kept)...
and here's the kicker... even with nitrogen, you can still get a nail in a tire, which still requires you to check the air pressure in your tires, so, the original benefit of nitrogen is almost a moot point as well...
Old 07-02-08, 10:30 AM
aristo2369
aristo2369's Avatar
Smile
from what i know, nitrogen will not get as hot/warm as regular air but i dont know how much cooler but i know thats the only benefit.
FUZCO
RC - 1st Gen (2015-present)
12-01-15 03:53 PM
2015isboy
11-12-14 07:53 AM
horent135
01-21-09 04:59 AM
Flipsonic
09-24-06 09:59 PM
Rx900
08-03-06 05:00 PM
Quick Reply: Nitrogen in Run Flats
