Steering Wheel Shake When It Rains
Old 05-22-08, 10:58 AM
ted920
ted920's Avatar
Default Steering Wheel Shake When It Rains
I get some steering wheel shake and vibration when it rains hard (highway driving) but when its dry, I hqave no problems at all.
What gives?
If it was a tire balance issue, I would expect it to vibrate/shake ain all conditions and not just when it rains hard.
Your opinions/ ideas are much appreciated.
Ted
Old 05-22-08, 11:10 AM
link13
link13's Avatar
Do you have 3 piece wheels? What does the inner part of your wheels look like behind the spokes? If there's any cupping to the inner portion at all, water will collect in there and throw off the balance. You can stop and mop out the water with a towel to relieve it temporarily. It doesn't rain much here in CA, so I just accept it when it happens.
Old 05-22-08, 01:37 PM
rominl
exclusive matchup
rominl's Avatar
yeah i suppose you have 2/3 piece wheels. it's common problem coz' water is trapped inside the barrel, and when you get up to around 70mph, it shakes
Old 05-23-08, 01:44 PM
ted920
ted920's Avatar
Thanks guys - you hit the nail right onthe head!!!!!
I knew the experts on CL would have an answer.
Yes, I do have 3-piece wheels and I believe what you're saying is absolutely correct.
Thanks.
Ted
Old 05-23-08, 01:51 PM
rominl
exclusive matchup
rominl's Avatar
yes, so in heavy rain i usually keep it around 60mph and i am good
Old 05-24-08, 01:51 PM
sleeper408
sleeper408's Avatar
Doesn't this happen more frequently also with 3-piece wheels with the reverse lip design? Or do most 3-piece wheels have this problem.
Old 05-24-08, 04:47 PM
radicalrev
radicalrev's Avatar
yep..my 2 piece reverse lip traps water too...
Old 06-03-08, 02:43 PM
TXFM
TXFM's Avatar
I was about to post the same subject about steering wheel/front end wobble in heavy rain to see how many others have the same problem.
I, too, have 3-pc wheels. I believe that we need a "sticky" in the forum to advise members of this problem with 2 and 3 piece wheels. It is not a mis-manufacturing issue by the wheel vendor at all. It is a result of the construction design required for reverse rim wheels. Otherwise, I am very pleased with my wheels.
There is an aftermarket solution for this. I have a product from TPMS Solutions out of Anaheim, CA for a water diverter product for the "TPMS SOLUTION REVERSE LIP WATER DIVERTER", but have not installed them yet. The concept sounds right.
When I finally get the time to install these and then it rains hard again in North Texas (could be a while!), I'll report back.
Last edited by TXFM; 06-03-08 at 02:44 PM. Reason: I couldn't attach the pdf so I'm deleting this sentence.
Old 06-05-08, 11:20 AM
sleeper408
sleeper408's Avatar
It sucks to have a high quality 3 piece wheel only to have this problem.
Old 06-16-08, 07:14 AM
TXFM
TXFM's Avatar
Well, I had the Water Diverters installed on my SC430 on Fri at Discount Tires. They had a good technician who knew his stuff. Now all I have to do is wait for it to rain hard to see if they work. Waiting.... waiting..... waiting...
Old 06-16-08, 01:28 PM
sleeper408
sleeper408's Avatar
How much was it to get installed? You didn't happen to take any pictures did you? I just recently acquired some 3 piece wheels and may get these water diverters. Either that or just run my "winter" wheels.
Old 06-16-08, 02:28 PM
TXFM
TXFM's Avatar
I didn't take any pictures. Cost me $64 for unmount/remount/balance.
Old 06-16-08, 03:06 PM
rominl
exclusive matchup
rominl's Avatar
shouldn't the water diverters be visible? i wonder what it looks like too
Old 06-16-08, 03:33 PM
TXFM
TXFM's Avatar
Ok, Henry, clearly I need to take a picture, but remember that they're on the inside of the wheel. I'll try to do it tonight.
Old 06-16-08, 03:41 PM
rominl
exclusive matchup
rominl's Avatar
come on, it's time to work out
Quick Reply: Steering Wheel Shake When It Rains
