LS400 wheel spacer help needed!!!!!
I sold my 2nd gen gs300 and purchased a 1997 Ls400. I want to put the wheels from the gs300 on the Ls400 but they dont clear the caliper; what size spacers do I need? They are 20x8.5 ET35 and 20x10 ET41 need to know asap.....Thanks
BahHumBug
its not an offset that will make a difference, its the wheel style and how the spokes curve in.
depending on the wheel u could get away with a 5mm or like most you would need a 15mm spacer.
the problem is that would drop ur front offset down to +20, which is going to require a roll and most likely a decent pull to fit properly.....and it will still stick out...
PHML
Suspension and Brakes
29
02-16-16 07:20 PM
