245 vs 225
Old 04-25-08, 01:03 PM
platinumac
platinumac's Avatar
Default 245 vs 225
I'm the first to admit I know nothing about wheels and or tires. All I know is I am getting a set of wheels. They are 20x8.5, with a 35mm offset (it's the same wheel/tire for all four tires front and back). The guy at the shop said the 245/35/20's most likely will fit fine with no rubbing or problems but he said the 225/35/20 will fit guaranteed (going on a '00 gs300) with no issues but that the 225's offer less protection to the wheels. Is there a big difference with the 245 and 225 for 20's? Anyone with a 2nd gen gs300 have 245/35/20's or 225/35/20's?
Old 04-25-08, 01:18 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
245/35 20 should be fine.
Old 04-25-08, 01:21 PM
platinumac
platinumac's Avatar
is there a big difference between the 225 and 245 as far as protecting the rim? i also heard the 225 gives it a stretched look? sorry to keep bugging everyone, i just want to ensure what i get will work...
Old 04-25-08, 08:32 PM
eclipse604
eclipse604's Avatar
http://www.1010tires.com/tiresizecalculator.asp
this is the calculator tool i normally use. quite detailed. it tells you how wide the 2 sizes are and the different between them
Old 04-25-08, 09:38 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I hate to point out the obvious, but a 245 is 20mm wider than a 225...
that first number is section width in millimeters...
Colly3
Build Threads
08-22-16 11:06 PM
platinumac
05-20-14 05:16 PM
Mv350
06-09-12 10:35 PM
MABmarc
05-20-10 12:58 PM
05ES330
08-12-09 02:29 PM
Quick Reply: 245 vs 225
