RFT Tires Front, NON-RFT Rears
Old 04-15-08, 09:12 PM
istundra
istundra's Avatar
Default RFT Tires Front, NON-RFT Rears
Hello,
I currently have Bridgestone Potenza RE050A RFT as fronts 225/40/18 and Bridgestone Potenza RE050A Pole Position (non-RFT) as rears 255/40/18.
Is this dangerous in anyway?
Thank you
Old 04-16-08, 04:36 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Originally Posted by istundra
Hello,
Thank you
not really... rule of thumb is that the rears are a higher performance rating and wider or the same as the fronts... run flat vs non run flat should not make a difference when we talk about performance that way...
Old 04-16-08, 08:26 PM
istundra
istundra's Avatar
Looks like i am OK. Fronts are rated at 168MPH and Rears are rated at 186MPH.
Thank you!
vutony
Wheels and Tires Classifieds
05-06-12 08:44 AM
jk7d
04-16-10 12:41 AM
RamshakleZ
11-19-08 07:51 PM
DoWnAqT
04-07-08 04:54 PM
Quick Reply: RFT Tires Front, NON-RFT Rears
