Amistad Wheels Size
Old 04-13-08, 09:43 PM
Snake83
Snake83's Avatar
Default Amistad Wheels Size
Hi all,
am trying to get Amistad Type C for my Lexus Gs430 2007 Model
and i need max deep dish possible ( big lip )
for 20inch wheel they have only :
20x8.5 +??
20x9.5 +??
can anyone give the right offset for max deep dish please
the site is : http://www.amistad.ne.jp/c/
thanks
Old 04-14-08, 12:37 AM
anotherLS
anotherLS's Avatar
do you wanna do fender mods??? and what are you lowered on??
my suggestion 20x8.5 high disk +31(60 mm lip) or +28(63 mm lip)
20x9.5 super low +29(105mm lip)or +26(108 mm lip)
front a little more than 2 inches and rear 4 inches
Old 04-14-08, 01:25 AM
Snake83
Snake83's Avatar
dear anotherLS
i will not do any fender mod. and i have already change my spring with
RS-R Ti2000 its japanse brand same like tein H tech Lowring.
so, what i need is to have the right size for deepest dish rim possible coz i will pay to much.
Old 04-14-08, 01:32 AM
anotherLS
anotherLS's Avatar
with the offsets i gave you, you will be ok...no fender mods required, if you want more conservative (less lip) than you go to the next higher + number
Old 04-14-08, 01:43 AM
Snake83
Snake83's Avatar
if i go for:
20x8.5 +28 high (63 mm lip) front
20x9.5 +26 super low (108 mm lip) rear
it will solve my problem and it will not touch the brake caliper (i have stock caliper)?????
Old 04-14-08, 03:21 AM
anotherLS
anotherLS's Avatar
will not touch stock caliper...with high disk you can even run big brake kit
Old 04-14-08, 06:21 AM
Snake83
Snake83's Avatar
so i should order the offset you gave me dear
what about the color i saw this picture and i need to know what is this color ??
SBC or Platiunm Black ????
Old 04-14-08, 06:29 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
I can't say with 100% certainty but they look like Platinum Black to me, SBC has more of shinier, lustrous finish.
Old 04-14-08, 12:04 PM
anotherLS
anotherLS's Avatar
i second the notion with Seize hes my homie!
Old 04-14-08, 02:05 PM
rominl
exclusive matchup
rominl's Avatar
if i go for:
you sure that requires no fender mods? 9.5 +26?
Old 04-14-08, 02:17 PM
Snake83
Snake83's Avatar
dear rominl
i dont know i just looking for the right offsets that it can lead me for deepest dish possible ??
so i dont have any idea now what to do shall i order the rims or double check the offset again ??
Old 04-14-08, 03:01 PM
rominl
exclusive matchup
rominl's Avatar
dear rominl
maybe anotherLS can elaborate more on the offsets. he didn't mention about stretching tires or camber, etc... i am very surprised if those offsets would fit with normal tires setup and no fender mods.
Old 04-14-08, 03:12 PM
anotherLS
anotherLS's Avatar
yup Henry did those offsets before and no tire stretch still can run a 255/35-20 or 265/30-20 on the rear. but if he wants to be more safer like if he has alot more passengers in the back he can do +32 and still get 102mm of lip still 4"...and run a 275/30-20 no camber required since your springs only lower the vehicle approx.1.2" with the RS-R springs those are pretty stiff springs...
if you compare this set up to Ryan (flipside909) then he has a 20x9.5 front and 20x11 rear and his offsets have to be in the +40's? so his front are 1" wider so you can compensate for width with more offset (hence the 8.5 +28mm or lil more than 1 inch which is actually smaller than Ryans set-up to achieve more lip than overall width...and the rear Ryan has a 11" and Snake wants a 9.5 overall a difference of 1.5" which translates to 37mm difference and he can get more lip than width
so with those calculations he can run those offsets and tires, without modifying fender or camber
Old 04-14-08, 04:34 PM
rominl
exclusive matchup
rominl's Avatar
please check pm
Old 04-14-08, 11:17 PM
Snake83
Snake83's Avatar
i will wait till we decide guys
Quick Reply: Amistad Wheels Size
