Tire size to replace run flats.
Old 01-13-08, 06:54 AM
bobl
bobl's Avatar
Default Tire size to replace run flats.
I need to replace the tires on my 2007 GS 450h. Dunlop run flat P245/40R18.
What size would work in a regular tire.
Also any recommendations for brand of tire?
Old 01-16-08, 02:01 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
You would use the same size. I like the Bridgestone RE960 A/S Pole Position in that size.
Old 01-23-08, 01:48 PM
kevinclee
kevinclee's Avatar
So is it possible to replace to the traditional tires with the OEM rims? Is it possible to fix a run flat tire with a screw on it? Mine is Dunlop SP5000 DSST 225/50VR17. If they can be replaced to the traditional tires, any recommendations for brands?
Old 01-25-08, 08:12 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
It is possible to replace with regular tires as long as you are aware you won't have the run flat capability. Most run flat tire manufacturers do not recommend repairing them. I recommended the Bridgestone in my last post.
Old 01-26-08, 12:12 PM
larrs
larrs's Avatar
Hi Brandon,
Curious to know why you like this tire (Bridgestone RE960 A/S). I read the sticky at the top.
In a comparison test on your site, the results are very close, but it came in 4th of 4 tires tested.
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=87
Your rankings are different?
In any case, what is your recommendation in 225-50/17 for an all-season tire that when snow/ice/slush traction is the top priority, with noise and comfort tied for 2nd priority?
Old 01-27-08, 10:17 PM
LA Wheel
LA Wheel's Avatar
I had that same exact tire on my LS430 UL. in 18" and 20" sizes. Very nice, smooth and quiet. Those ratings don't lie. Highly recommended!
Weighit
Hybrid Technology
04-09-21 03:38 PM
deusex
LX - 3rd Gen (2008-2021)
06-24-19 08:23 PM
jbobst
10-02-17 05:40 PM
junjdm
04-28-07 07:33 AM
Jmai22
10-31-04 01:57 AM
Quick Reply: Tire size to replace run flats.
