Anyone know how to replace the wheel lug?
I was testing how some new rims would look in the wheel well and when I took my stock wheels off, one of the lugs broke(the stud, not the nut). I bought a new lug and nut from autozone and just wanted know if anyone knows the best way to replace these? Do I have to take the entire caliper off to access the back side of the rotor or is there an easier way? Trying to save myself a potential headache. Thanks
Addition: I didn't realize this needed to be in the tire section, but this is in reference to the 1stGen GS300. I have no clue if this is different between models.
These instructions are for a 2002 GS but they may be the same for you:
TheWHEEL HUB BOLT
REPLACEMENT
1. REMOVE REAR WHEEL
2. REMOVE BRAKE CALIPER AND DISC
(a) Remove the 2 bolts and remove the brake caliper from the
axle carrier.
(b) Support the brake caliper securely.
(c) Remove the disc.
3. REMOVE HUB BOLT
Using SST, remove the hub bolt.
SST 09628-1001 1
4. INSTALL HUB BOLT
(a) Install a washer and nut to the bolt, as shown in the illustration.
(b) Turn the wheel nut to pull the hub bolt until the underside
of the hub bolt head touches the axle hub.
5. INSTALL DISC AND BRAKE CALIPER
(a) Install the disc.
(b) Install the brake caliper and 2 bolts to the axle carrier.
Torque: 104 N•m (1,065 kgf•cm, 77 ft•lbf)
6. INSTALL REAR WHEEL
Torque: 103 N•m (1,050 kgf•cm, 76 ft•lbf)
WHEEL HUB BOLT
REPLACEMENT
1. REMOVE FRONT WHEEL
steering knuckle.
3. REMOVE HUB BOLT
SST 09628-1001 1
4. INSTALL HUB BOLT
(b) Install the brake caliper and 2 bolts to the steering
knuckle.
Torque: 118 N•m (1,200 kgf•cm, 87 ft•lbf)
6. INSTALL FRONT WHEEL
TheWHEEL HUB BOLT
REPLACEMENT
axle carrier.
3. REMOVE HUB BOLT
SST 09628-1001 1
4. INSTALL HUB BOLT
WHEEL HUB BOLT
REPLACEMENT
steering knuckle.
3. REMOVE HUB BOLT
SST 09628-1001 1
4. INSTALL HUB BOLT
knuckle.
Thanks. I figured there might be an easier way, but guess not. It worked fine by the way. All done in just a few minutes and saved myself some money. Thanks BCP43002.
