Proper tire size for a 20" rim
Old 11-16-07, 10:23 PM
tomtsops
tomtsops's Avatar
Default Proper tire size for a 20" rim
I've got a pair of 20's, 20x9.5 rear, and 20x8.5 front. Does anyone see a problem with running 275/30/20 and 245/35/20 with these rims?
Both front and rear have an offset of +35.
I think the ideal case would be to have 25 series in the back, and 30 series in the front, however there's barely any selection at that size on tirerack. Any suggestions are welcome.
Thanks,
Old 11-16-07, 10:58 PM
V8_Aristo
Bippu
V8_Aristo's Avatar
You forgot to mention what car it is.
Old 11-16-07, 11:31 PM
tomtsops
tomtsops's Avatar
My bad. Its a 2002 GS300.
Old 11-17-07, 10:54 AM
V8_Aristo
Bippu
V8_Aristo's Avatar
A lot of members run the oversized 245/35/20 and 275/30/20, I even had it on my own car at one point with the same offset. It should be fine as long as you don't lower the car too much. Since it's over sized, the tires will hit the fenders before the suspension bottoms out when the front wheels are turn.
Old 11-17-07, 03:53 PM
tomtsops
tomtsops's Avatar
Thanks V8. I don't think i would drop it too much anyway (just enough so that it looks clean). You didn't have to shave or roll your fenders did you?
Old 11-17-07, 07:37 PM
V8_Aristo
Bippu
V8_Aristo's Avatar
I shaved my rear fenders from a previous set, but I've seen members with the same specs run w/o fender mods.
Old 11-18-07, 03:50 PM
tomtsops
tomtsops's Avatar
thanks for the info.
PawnStar23
04-24-17 06:24 PM
SpaceCadet
01-24-13 06:37 AM
tomtsops
10-03-07 04:36 PM
cmc07e
04-13-07 08:18 AM
02Ku
04-06-06 08:42 AM
Quick Reply: Proper tire size for a 20" rim
