05 Maxima wheels on 94 LS400?
the bolt pattern and offset is the same, lug thread on LS is 12x1.5 while maxima's is 12x1.25, and hub center is different (as per sizeitup.com). I know very little about wheel fitment, so can anyone tell me if I will run into problems using a wheel taken from the maxima on my 94 LS?
i searched and didn't find anything.
They are actually aftermarket rims. I've confirmed with a few sources that the bolt pattern is identical and so is offset between the OEM rims of these two cars.
Basically I have these four tires with rims sitting around and just found out they have the same specs as the OEM rims on my 94 LS (which desperately needs to lose the stock ugly 16s).
Do I need to do anything for them to fit? And can I do this myself with a jack?
Edit: last part assumes they are balanced
wcoastls
26
05-02-11 09:51 PM
