Will these tires fit?
Old 10-14-07, 03:29 PM
PetesLS400
PetesLS400's Avatar
Default Will these tires fit?
I'm shopping around for winter tires and found a good price on some non OEM sizes.
225/55/17
and
235/55/17
OEM is 235/45/17
Will the added height be enough to create an issue?
Old 10-14-07, 07:58 PM
PetesLS400
PetesLS400's Avatar
Had this posted in the 2GS section until a mod moved it
So these are going on a 2nd gen GS.
Anyone know if these will fit?
Old 10-14-07, 08:02 PM
Spyder78
Spyder78's Avatar
they should fit the height difference will throw your speedo out of whack slightly.
Old 10-14-07, 08:53 PM
PetesLS400
PetesLS400's Avatar
...............THanks
Old 10-17-07, 10:30 AM
RobS
RobS's Avatar
I don't think it is a good idea to mount either size on your GS. Going from 235/45-17 to 225/55-17 is 5.6% too slow. When your speedometer reads 60 mph, you are actually travelling 63.4 mph. Going to 235/55-17 is worse. It makes a 7.3% difference. As a rule of thumb, you don't want to be off by more than 4%. If you want non-OEM size winter tire, you might want to look at 215/50-17. Good luck.
Old 10-18-07, 08:34 PM
qttire1
qttire1's Avatar
check out this site www.sizeitup.com great website for
fitment info, seems to right on fitments and wheel specs
ThumperPup
11-28-15 06:37 PM
rena
10-20-12 10:03 PM
frantinez
06-25-09 12:05 AM
DallasGuy
07-16-08 02:45 PM
NYC Max
12-26-03 11:29 AM
Quick Reply: Will these tires fit?
