My new wheels: Work Euroline S2H
#62
forgive me for asking, you need to buy separate hubcentric ring?? I thought high end wheels (works..) would come with everything you need? And is that something that's needed? Or is it just an addon that you choose to put on for better balance of the wheels?
thanks,
thanks,
#63
gs4
I tried pm u, but your box was full. The invoice did not
have the size of the ctr-ring nor could I find the package
that the ctrrings came in. I would suggest that if you order wheels from mark you have him ask his contact in Japan to either findout the proper size of the ctrrings or get them. Maybe even the lugnuts too. That way you'll have everything you need and won't have to spend extra bucks.
By the way, I now have to carry a 19mm socket and breaker bar 4 my new lugnuts.
#66
I will certainly ask for the ctrring next time.
Hi all, I guess I am not wheel experts like Manaray or gs4will. But I guess that centric ring seems to be a big issue. As I understand, when I received the wheels, the package did not come with any centric ring. Initially, when I ordered my own wheels I thought Work will supply that but I was mistaken. However, I think if its only cost me like 5-10 bucks to get them, I don't mind spending that money when I have my wheels put on. Anyways, since I am the person selling the wheels I should provide not only an attractive price, but also getting something that is needed to install the wheels right. Next time, if there is anyone else place an order through me, I will definitely contact Japan regarding this. Thanks to strshooter for the comment and I apologize for all the inconvenience. P.S. Just order a set of 19" Work Vs SD2 for MCGONG. Mike, I will try to find out if they can get you the centric ring. Hope its not too late.
#69
Originally posted by mcgong
Just wondering, how come u can't use the stock lugnuts for Work Wheels?
#71
Originally posted by damnboy
Stock lug are too big to fit, same as the stock wheel lock.
Those are cheap compare to the rim and I think new wheel deserve new lug. just my 2 cents.
#72
Did you get now wheel locks. How much were they?
#74
lex430,
or, you can also call www.summitracing.com and ask for either Mcguard or Gorilla brand lugs(12-1.5mm) and lock set at a very good price..they will ask you what's your car model and match the right size..
#75
Originally posted by gs4will
lex430,
lex430,
So the gorilla set will fit Work Wheels? 27 dollars a set seems like a pretty good price.
