Noob Rim Question!
Old 09-19-07, 09:19 AM
hurricane
hurricane's Avatar
Default Noob Rim Question!
OK JUST BOUGHT AN 99 LEXUS GS400 BLK.. WAS GOING TO PUT ON BLK 20'S. i was told when i bought the car it had h&r springs on it cause it sits kind of low ... anyways i tried to put on 20X9 rims and the back stuck out aloottt .. looked wierd.. will 20X8.5 be good all around or will it look stupid same size all around ? and with spring in there can i use /35/ or must i use /30/ tires because he told me 35 would rub ..anyways anyone with h&R spring and 20's what would be a good rim/tire combo size that fits perfect..
Old 09-19-07, 10:20 AM
carbongs
carbongs's Avatar
you need to look up the correct offsets
Old 09-19-07, 01:21 PM
Bigbea
Bigbea's Avatar
Check in the suspension section. Offset is definately the key. I have 20x8.5 with a +42 offset and my car is pretty low and no rubby rubby
Old 09-19-07, 05:45 PM
hurricane
hurricane's Avatar
will do brotha tnks
Old 09-19-07, 06:07 PM
greyBLITZ
greyBLITZ's Avatar
yes, offset is correct. Also keep in mind, higher offset will put them closer in, while lower, or negative offset will stick them out further.
tures
06-02-13 03:47 PM
minnyminh
06-06-09 05:43 PM
yusef
02-11-08 07:15 PM
Alexus-Kia
07-09-04 09:29 AM
GS400drive
12-08-03 08:57 PM
Quick Reply: Noob Rim Question!
