Widest wheel spacer i can go on a gs400
Old 09-18-07, 10:27 AM
jtgs400
jtgs400's Avatar
Default Widest wheel spacer i can go on a gs400
I'm on the 06+ 18" 5 spoke gs wheels. The rear offset is just way too conservative and was wondering what is the thickest wheel spacer I can go on the stock studs. I found some generic wheel spacer in my garage and was wondering if theyre safe to put on. They're about 5mm thick with a universal bolt pattern and a huge hole in the middle. Looks like this thing will have a lot of free play until the wheel is tighten against it.
Old 09-18-07, 10:30 AM
JLAM
JLAM's Avatar
i think 5mm is ok...anything more I used use longer studs or bolt on spacers.
Old 09-18-07, 10:55 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
bad idea.... the wheel is no longer going to be hubcentric with that generic spacer...
better off to get a vehicle specific spacer and the extended studs (or a bolt on adapter plate) if you plan on going 15mm or more... 5-10mm, then get a hubcentric ring and extended studs...
celsior123
07-13-23 11:09 PM
primavera
07-14-18 03:11 PM
puff
05-20-14 08:43 PM
chanho083
06-25-11 09:35 PM
airwrench
05-13-09 09:09 AM
Quick Reply: Widest wheel spacer i can go on a gs400
