GS wheel fitment help needed!
i need help from folks out there familiar with GS400 fitments:
19X9.5" +45mm front with about 2.5" lip (A Disk) 5X114.3
19X10.5" +45mm rear with about 3.25" lip (A Disk) 5X114.3
the GS is lowered on tein CS coils, and the fenders are rolled. trying to get a 1 finger gap if i don't bottom out on the coilover threads.
i've been warned that the fronts might rub on the inside against the teins, but i have nothing substantial to confirm. i cannot test fit since i'm in canada and the wheels.... are not
help?
help?
The fronts will need a spacer - probably 4-5mm.
The coilovers won't affect the wheel clearance; the GS has an upright arm connecting the upper and lower A-arms together, and this is where the front wheels will hit.
Rear wheels should be fairly straightforward, depending on tire you choose.
