Tire Pressure Help
Old 06-27-07, 11:08 AM
Hartawan
Former Vendor
Hartawan's Avatar
Question Tire Pressure Help
I am currently running,
Front: 20x8.5 245/30/20 40 psi
Rear: 20x10.0 285/25/20 36psi
What is the correct pressure to run on?
Old 06-27-07, 11:35 AM
bb430
bb430's Avatar
I would not go as high as 40 psi unless you are worry about deep potholes and even that you might just blow the tire if run over one.
I would try 34 front 36 rear or just 35 all around.
Old 06-27-07, 07:11 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
only problem with that is load carrying capacity...
certain tires, specifically those with low volumes of air (low profile) will need higher air pressures than standard...
any clue what the load index and weight carrying capacities are of the tires in question?
Old 06-28-07, 01:24 PM
Hartawan
Former Vendor
Hartawan's Avatar
90Y front [1323lbs/186mph]
93Y rear [1433lbs/186mph]
Running Falken 452s
y2tony3
03-12-16 10:43 AM
gebo
03-12-15 06:37 AM
jarm
11-08-10 10:10 AM
flossn
04-04-05 12:17 AM
GS4ADRLexo
01-26-03 11:56 PM
Quick Reply: Tire Pressure Help
