What will Stainless Steel brake Lines do for my SC430?
Old 05-09-07, 08:28 AM
rclab1
rclab1's Avatar
Default What will Stainless Steel brake Lines do for my SC430?
Newbie Questions.....
First off, I don't really like the smushy feel off my brakes when depressed,
is it true that upgrading to Stainless Steel brake Lines increase my brake pedal feel?
I have OEM brakes on as for now.... and planning on upgrading to Rotora Rotors and Hawk ceramic pads very soon....
.....bottom line is, what do Stainless steel brake lines do if I have the OEM brake set up?
Old 05-09-07, 03:11 PM
GSteg
GSteg's Avatar
going with the stainless steel lines will improve the pedal travel. But don't expect a change in stopping distance or dramatic difference in pedal feel. I've never felt an OEM Toyota brake that felt good. They're all mushy and lack feel. If you want more feel and response, upgrade to some big brake kit.
Old 05-09-07, 03:48 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I agree...
I have always been a big proponent of not needing stainless lines 99% of the time...
it typically increases pedal feel about 5%, maybe less depending on car...
what I would recommend, however, is getting the fluid replaced and bled with a good quality brake fluid... this will achieve about 95% of what going to stainless lines would (as most of the perceived better pedal feel with SS lines is really that the person just replaced fluid and bled the system)
Old 05-09-07, 06:28 PM
rclab1
rclab1's Avatar
Default ????????
so what you are saying is that too keep my OEM brake lines for now and bleed off my brake fluids?
what brake fluids do you recommend? OEM or a special aftermarket one?
will keeping my OEM brake lines and replacing with aftermarket brake fluid increase my brake pedal feel (in other words, sort of does what SS brake lines do?)
thanks....
Old 05-09-07, 10:03 PM
mitsuguy
mitsuguy's Avatar
OE fluid works well, I personally like Motul fluids... and there are plenty of others out there too...
chances are that if it's been a while since the brakes have been bled, this will give you a much better pedal feel... similar to installing ss lines...
now, ss lines might be better still, but again, against a properly functioning brake system, you would be hard pressed to tell the difference...
amiehe
Suspension and Brakes
03-20-11 12:30 PM
Lexus082
15
10-17-07 03:39 PM
Benjamin T
08-15-07 08:33 AM
3dog
17
12-30-04 10:42 AM
Black_IS300
06-29-01 09:12 PM
Quick Reply: What will Stainless Steel brake Lines do for my SC430?
