IS 18" wheels --> ES300
Old 05-03-07, 02:58 PM
RamshakleZ
RamshakleZ's Avatar
Question IS 18" wheels --> ES300
I am looking to sell my 18" stock wheels from my 2007 IS 350 and have an offer from someone who wants to put them on their 1998 ES 300.
I went to Discount Tire Co. here in Houston and asked them if my wheels would fit on an ES 300. They said "it depends." He said that by looking at the possible tire combinations in his computer, the front wheels + tires should fit just fine. But, because we have staggard wheels, the back ones may not fit. The wheels themselves will obviously fit but once you put the tries on them, it might scrub.
He did say that he didn't know if the wheel itself is staggared or if the wheels are the same size but the tires are different sizes. If the latter is true, it will work just fine because the person putting them on their ES300 would just use the same size tire an all 4 wheels.
So - my question is this... any idea if an 18" IS 350 wheel will fit on a 1998 ES300???
Old 05-04-07, 11:14 AM
Zyoxx
Zyoxx's Avatar
the ES has the same bolt pattern (5x114.3) and the same center hub (60.1) so the IS wheels should bolt on. The 98 ES300 can fit a 20x8.5 so the stock IS wheels should be no problem.
Old 05-06-07, 01:09 PM
Choas
Choas's Avatar
Not the is350 rim the rear is 9" wide. The only way to put them on is to do what i'm doing that is to buy longer studs and 12mm spacers and i'm not sure if that will work.
Old 05-06-07, 01:14 PM
Choas
Choas's Avatar
Oh and i have 225/40/18's on all 4 tires.
Old 05-07-07, 08:41 PM
Alexus_300
Alexus_300's Avatar
No!!! The stock IS350 rear wheel is 8.5" wide and runs on 255-40-18's. Don't ask me how I know..
Old 05-20-07, 08:04 PM
Narco
Narco's Avatar
can someone elaborate. I am the person wanting to buy these.
Old 05-23-07, 10:50 PM
chrispy
chrispy's Avatar
You can get them to fit by using a spacer and running thinner tires. Maybe shaving or rolling the fenders too.
Dialtone
10-11-12 10:49 PM
jimbo409
06-17-09 12:34 PM
zajac
03-30-09 10:36 PM
Garwow
07-16-03 02:42 PM
Quick Reply: IS 18" wheels --> ES300
