Hub Rings for LS460
Old 04-27-07, 09:14 AM
bippu
bippu's Avatar
Default Hub Rings for LS460
I am trying to put on some new set of wheels meant for the BMW 7 Series on the LS.
The only issue is that I am going to need to get different lug nuts and hub rings.
The hub diameter on the wheel is 72.5mm and I am not sure if the LS460 is the traditional 60.1mm.
If anyone can confirm on the hub ring as well as let me know a shop to get them,that would be great.
Old 04-27-07, 10:13 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
The only other issue is that the bolt patterns are different.
Old 04-27-07, 12:56 PM
bippu
bippu's Avatar
The new Lexus LS460 has the 5H120, which is the same as the BMW.
The wheels that I am putting on are 20 - 9.0 +20 front and 20 - 10.0 +20 rear.
http://www.m5board.com/vbulletin/sho...highlight=neez
(post#47)
On the first thread the wheel picture is on post#47.
Old 04-27-07, 04:31 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Holy crap your right! I'm shocked Lexus is using a BMW bolt pattern and frankly a little annoyed. Thanks bippu for posting this info!
Old 04-28-07, 07:35 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
no kidding... If I wouldn't have read this, I would have kept thinking they were 5-4.5
damn Lexus, why would they do that...
Old 04-28-07, 08:39 AM
bippu
bippu's Avatar
A little shocked here my self... don't really understand the reason for it....
I am still going to need a place to source the hub rings and lug nuts that have the same taper as BMW wheels.
Appreciate all the help...
Old 04-29-07, 10:58 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
u can get hub rings made (ask some of the 2GS/1SC guys, they know where) but regular conical lugs should work. bmw uses lug studs which screw into the hub so the bolt looks like this :
versus this :
Old 04-29-07, 11:20 PM
mitsuguy
mitsuguy's Avatar
one thing that needs to be made sure, is that the correct taper is used - standard taper if it's a normal seat wheel, however many mercedes /bmw / audi wheels use a bal seat which are rounded instead of a flat angle...
Old 05-01-07, 12:15 AM
SoCalSC4
SoCalSC4's Avatar
Just an FYI: Lexus corporate does not allow dealers to install wheels that are not hub-centric on the LS due to related vibration issues. It doesn't sound like you're a dealership, so it might not be a issue - provided you use the correct rings and have a 'road force' balance performed - but if you encounter a vibration issue, don't expect the dealer to diagnose or fix it with those wheels on it.
Old 05-03-07, 06:58 AM
bippu
bippu's Avatar
Thanks for the info SoCalSC4.
I am still looking for those hub rings ???
droo
Wheels and Tires Classifieds
11-13-16 12:37 PM
interlago
05-11-13 08:47 AM
interlago
11-06-11 07:06 PM
bigcory
04-15-08 07:30 AM
junkyardje
07-24-07 07:15 AM
Quick Reply: Hub Rings for LS460
