18 X 8 30; 18 X 9 33 - GS400, will these fit and anyone have tire recommendations
I am a tire and wheel noob, did extensive search, LGW's website is down or I would Reference Rominl's guide,but I can't find it. Any info would be appreciated, Tire and Tire size recommends from those that know would be appreciated as well. Thanks They are 18 X 8 w/30 offset and 18 X 9 33 offset. Would they fit, any modifications needed? - tire size and tire brands would be appreciated as well. Thanks to all that know more about this stuff than I do - which means everyones comments would be appreciated.
Maintenance Moderator
i am no expert on the GS stuff, but they look like reasonable sizes...
in terms of tire size, just search, there is plenty of info already in this forum
in terms of tire selection, get the best your wallet will handle - BFG, Michelin, Goodyear, Bridgestone on the high end, Fuzion, Falken, Kumho on the lower end...
I think the wheel size is throwing you off. Since most of the application for the GS are 8.5/9 (front) and 9.5/10 (rear). I don't know if you wanted to go aggressive or conservative on your set up, so I will just give you the equivalent sizes and you make up your mind on what you want.
18x8 +30 = 18x8.5 +37
= 18x9 +42
18x9 +33 = 18x9.5 +40
= 18x10 +45
= 18x9 +42
= 18x10 +45
Thank you, this is very helpful. Is 18 X 8 and 18X 9 too narrow, and does anyone know the widest tire that I would be able to fit on the back.
Thanks
Thanks
= 18x9 +42
= 18x10 +45
= 18x9 +42
= 18x10 +45
That size would work. The rears might crown a little bit depending on what tire you decide to go with. What tire are you planning on going with? You cant go wrong with Pirelli. For ride quality, reliability, longevity, and handling I'd suggest the Pirelly PZero Nero.
