HELP, steering wheel shakes
Old 02-28-07, 06:04 AM
Silver GS
Silver GS's Avatar
Default HELP, steering wheel shakes
OK, so I bought some wheels and tires (purchased separately)from Tire Rack. I had them mounted and balanced at a local shop. I brought them back to my house and started to put them on my car. Well, I went to put on the first wheel and I noticed that w/ the hub centric ring the wheel would not sit flush against the rotor, when I tried to put the top lug nut on it would kick the bottom out, and vice versa. So, I took it off and it set flush like to should, or at least what I'm used to. I have never used hub centric rings for any of my wheels. I removed the rings from the rest of my wheels and finished the install.
My problem is that now I have a vibration in my steering wheel that was not there before, what gives?
Wheels: 19 x 8.5 w/ +42
Tires: 245/35/19
Could it be:
A. The wheels are no longer balanced because I removed the rings and when they were originally balanced they had the rings on the wheels. (can wheels be balanced with the rings on?)
B. Wheels and tires were not balanced correctly to begin with.
C. I need an alignment.
Please help.
Thanks,
Chris
Old 02-28-07, 07:11 AM
oohpapi44
oohpapi44's Avatar
Tires: 245/35/19
Could it be:
Please help.
Thanks,
Chris
You have the wrong size rings, if the rims need hubcentric rings and you don't put them on, you're going to vibrate. Go find the correct ring sizes and put them on. Then get an alignment
Old 02-28-07, 07:27 AM
Silver GS
Silver GS's Avatar
The rings were supplied by tire rack.
Where can I buy new rings or the correct rings?
Old 02-28-07, 07:53 AM
oohpapi44
oohpapi44's Avatar
http://cgi.ebay.com/ebaymotors/MAZDA...QQcmdZViewItem
Old 02-28-07, 08:31 AM
E-Z ES300
E-Z ES300's Avatar
I have a shaky steering wheel but i think mine could be a different problem mine is shaky when im braking on the freeway going about 60+ mph I believe mine is i have warped rotors and or unbalanced/warn out tires...
Old 02-28-07, 09:51 AM
Silver GS
Silver GS's Avatar
Sounds to me like you need your rotors resurfaced or you need new rotors
Old 02-28-07, 10:07 AM
E-Z ES300
E-Z ES300's Avatar
I guess im gonna have to do my cross-drilled/slotted rotor upgrade earlier then i thought....
Old 02-28-07, 10:11 AM
Silver GS
Silver GS's Avatar
That's a good thing, why the long face?
Old 02-28-07, 07:28 PM
E-Z ES300
E-Z ES300's Avatar
In the long run its an incredible thing, but for now i only get paid once every month so i gotta wait for that paycheck which is going to be on the 8th of March and i dont want to wait! But im gonna have to since i have NO money...
curt248
10-09-08 03:53 PM
MrLex22
Suspension and Brakes
12
06-03-07 06:07 PM
Kharizma
12-18-05 09:30 AM
spyder357
05-05-05 09:12 PM
Quick Reply: HELP, steering wheel shakes
