GS400: 19x8.5 +30 and 19x9.5 +25 too crazy?
Simple offset question, I've searched through all the posts and +38 to +42 is what everyone recommends for 98-05 GS's, but I'm wondering if these will fit at all?
http://www.discounttiredirect.com/di...w=8&bp=5-114.3
19x8.5 +30
For the front.
http://www.discounttiredirect.com/di...9.5&bp=5-114.3
19x9.5 +25
For the rear.
I don't mind a little bit of fender work (i.e. rolling) but I don't want to have to shave or cut anything...
I currently have Tein springs on KYB shocks... only lowered it about an inch or so I'd guess. If I have to use spacers on the rear that's cool too...
Thanks in advance for the help.
19x8.5 +30
For the front.
19x9.5 +25
For the rear.
There's quite a few members that are running more aggressive offsets than those. Tire size and brand will play a roll on getting them to fit, and rolling the fenders are going to be a must.
For example, if I was running the same size wheels as what you are planning to get. My specs would look like 19x8.5 +21 and 19x9.5 +18.
You might want to go with a more narrow tire. 235/35/19 and 265/30/19 if you want to be square with the wheels or 225/35/19 and 255/30/19 if you want a mild stretch look to it.
Yeah, those are over 1/4" more inboard than mine... ride height will have an affect on how they'll fit; the lower you go, the more inboard they will look.
I'd go with 265/30-19 rear (instead of 275) if you don't want to do significant rear fender mods. They won't really stretch at all on these narrow-ish wheels, so this may affect how they'll fit.
EV ftw!!!
What am I missing here when you just commented that he would have rubbing issues with the 275's on a 9.5 inch rim?
Question for you Bob, I have 275/35 on my 9.5 inch wheels at the back and the car is lowered so that you can barely fit your finger in between the tire and fender, however I don't have any issues with rubbing whatsoever and my fenders have not been modded either.
EV ftw!!!
Hi Hameed. It's all about the combination of tire offset, wheel width, and tire
For example, Michelins and the new Yokohama Advan Sport run "wider" than,
for example, a Nitto or Falken. This mostly has to do with the sidewall shape.
Some tires are more "square shouldered" than others.
That's why making wheels is so difficult- you test one car with a wheel and
tire, it works great... change the brand of tire and suddenly the tires rub!
As you said, you can barely get a finger between your tire & the fender...
I can barely get a credit card between mine... it looks nuts!
SNiiP3R
12-19-08 08:27 AM
