Need Tire Specs For Putting 19's On 2000 GS300
Old 01-15-07, 06:03 AM
Kareem
Kareem's Avatar
Exclamation Need Tire Specs For Putting 19's On 2000 GS300
I'm about to purchase a 2000 GS300
I want to put some 19's on it.
I've decided for a smoother ride.
And to keep from having a rubbing problem.
19's are big enough for the desired look.
I don't know anything about the whole "staggered" look.
Not a real big car guy.
So I'd appreciate somebody giving me the specs on what I need to order to put my 19's on without any extra mod's needed.
I don't know if I need 8.5's or 9's
The tire shops say I need the 8.5's though.....
Thank in advance
Old 01-15-07, 06:37 AM
AJ
AJ's Avatar
I say 8.5 front with 245/40/19 tires for the comfy ride and 10 rear with 275/35/19 .
And Welcome to CL
Old 01-15-07, 11:15 AM
Kareem
Kareem's Avatar
And Welcome to CL
Will there be any rubbing?
Will I need an additional modication?
Old 01-15-07, 01:43 PM
AJ
AJ's Avatar
Don't know , i have a thread about rubbing as well waiting for someone to chime in .
Old 01-15-07, 02:31 PM
Neo
The One
Neo's Avatar
If you want simple and avoid rubbing, go with 19x8.5 with an offset between 35 and 40. Use 245/35/19 tires.
If you are a little more ambitious and go staggered, use the above specs for the front. Then go with 19x10 with an offset between 42-45. Use 285/30/19 (or 275/30/19 if you cannot find the 285s) tires.
This is a modest spec that will not please the guys who really want to push the limits but it will be pretty nice without rubbing issues. Everything should be just insidethe fenders and the diameter is about OEM so any rubbing you get from this, you would probably have gotten with the OEM wheels.
In addition, read through this as it may help you with more info:
www.lgwnorcal.com/articles/wheelfitment.html
Old 01-17-07, 10:22 PM
pardo
pardo's Avatar
My GS has 19x8.5 +38 offset, all four rims (non-staggered). The car is lowered, with about 1 inch gap. I do not have any fender mod. The rear is not really flushed. But the non-staggered setup allows me to rotate tires.
Because the car is lowered, the rear rims can probably go 19x8.5 +32 without rubbing.
Attached Thumbnails Need Tire Specs For Putting 19's On 2000 GS300-my_gs_front.jpg
Old 01-21-07, 05:37 PM
mole
mole's Avatar
have you thought about a spacer in the rear to get the flush look and still be able to rotate?
Old 01-22-07, 08:15 PM
Supraristo
Supraristo's Avatar
Definately 8.5 with 245/35-19 38mm offset....rear 10 with 275/30-19 42-45mm offset. No rubbing and no fender rolling. Easy and carefree setup.
Old 01-22-07, 10:03 PM
treimche
treimche's Avatar
https://www.clublexus.com/forums/sho...d.php?t=226439
Check out that link, I got some good answers from that thread.
Johnjohn13
GS - 1st Gen (1993-1997)
02-26-08 08:56 PM
mhsu408
02-26-06 02:00 PM
supraman95
28
01-06-06 02:57 PM
mike-ibp03
04-13-05 09:34 PM
jbbnet
04-20-03 12:36 PM
Quick Reply: Need Tire Specs For Putting 19's On 2000 GS300
