Rub
Old 01-14-07, 03:51 PM
AJ
AJ's Avatar
Exclamation Rub
Will the following specs clear a 2GS with no rubbing or fender mods , and if mods are needed , state which .
Combo1:
19x9 +35
19x10.5 +29
Combo2:
19x9+35
19x10.5+41 OR 19x10 +47
Thanks
PS. Will be going with fat tire setup .
Old 01-14-07, 09:15 PM
pardo
pardo's Avatar
Combo1:
19x9 +35
19x10.5 +29
Combo2:
19x9+35
Thanks
I think the front with 19x9 +35 will rub
Old 01-15-07, 02:34 AM
AJ
AJ's Avatar
Too wide ? or too aggressive offset ?
Old 01-16-07, 06:23 AM
AJ
AJ's Avatar
Anyone ? ?
Old 01-16-07, 11:56 AM
LEXSOOS
LEXSOOS's Avatar
Combo #1 + fat setup will be totally out of spec = NO
Tire size&brand please!!!
Old 01-16-07, 01:12 PM
AJ
AJ's Avatar
Tires are : 245/40/19 & 275/35/19 Dunlop SP9000 . if its out of spec , will it rub ?
Old 01-16-07, 01:53 PM
Neo
The One
Neo's Avatar
The only wheel that will not rub is the 19x10 +47.
There will be a certain level of rubbing in the front anyway because of the fat setup. The only rubbing you can try to minimize is the fender. The wheelwell cover will get rubbed here and there. As for the fender, you will need to at least roll them.
A combination of both. 19x8.5 +35 will PROBABLY not rub or 19x9 +41 will do the same. As far as the fender flush goes, these two specs are basically the same. I say PROBABLY because a lot also depends on your drop, alignment, and tires. I've seen x8.5 +42 have some minor rubbing while x8.5 +35 reporting none.
When you are trying to push the envelop a little bit (and I am not even talking about the VIP setups), you will just have to accept that it might just rub a little once you get it on.
i2fat
06-23-15 10:35 AM
wum
12-25-11 10:41 AM
istundra
11-24-08 08:22 AM
mikemareen
07-30-07 09:15 AM
bighitbike
06-11-07 10:23 PM
Quick Reply: Rub
