will OEM G35 wheels fit the ISx50?
Old 12-31-06, 07:46 PM
dgis250
dgis250's Avatar
Default will OEM G35 wheels fit the ISx50?
Here's the specs:
fronts - 19x8 plus 30mm offset rears - 19x8 ½ plus 33mm offset
I think these rims are hot and I'd like to get a set if they'll fit
Old 12-31-06, 08:11 PM
cvex
cvex's Avatar
Stretch your tires by reducing the size, roll the fenders, and stock height. +33mm is over the limit i think. Ive seen a +37 and its right at the fender lip.
Old 12-31-06, 09:34 PM
AZ IS350
AZ IS350's Avatar
I think it will put you right at the hairy edge. Several people on here (including myself) have gone to +35 offsets front & rear, without problems, but I wouldn't go any less, especially on the rear. If you plan on lowering it too, then expect to have problems.
Old 01-01-07, 02:02 PM
2point5is
2point5is's Avatar
i dont think there the same bolt pattern are they?
Landon
Old 01-01-07, 05:13 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Landon
They share the same bolt pattern - 5 x 114
Socal300sd
07-19-09 01:36 PM
Duds
GS - 1st Gen (1993-1997)
15
12-02-06 09:40 PM
blk06is350
09-10-06 03:59 PM
Escobar
21
06-13-05 06:22 PM
howiedoit
SC- 1st Gen (1992-2000)
02-04-02 10:12 AM
Quick Reply: will OEM G35 wheels fit the ISx50?
