20x9 rim in front....245/30/20 or 255/30/20
Old 12-20-06, 02:34 AM
mjr24
mjr24's Avatar
Default 20x9 rim in front....245/30/20 or 255/30/20
Is there any advantage at all in buying 255/30/20 over a 245/30/20...or will they basically be the same.
Old 12-20-06, 11:53 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
Aside from the fact that they are 10mm wider???
Old 12-20-06, 02:48 PM
mjr24
mjr24's Avatar
Nice reply wise ***.
Old 12-20-06, 03:54 PM
Aristo300
Aristo300's Avatar
If you don't know what the variable in your tire size means, then how are you suppose to make a decision on which is best for YOU? Hopefully the 20" wheel you pick will have the correct offset and not decapitate the fender. I'd run a 245/35/20 IF you get the correct offset.
Old 12-20-06, 03:58 PM
mjr24
mjr24's Avatar
Exactly my point. I didn't say I didn't know the difference, I simply asked if there was an advantage. You said you would run a 245...why? There has to be a reason.
Old 12-21-06, 05:29 PM
tam4G63
tam4G63's Avatar
I agree with Aristo300, 245/35/20 would be best. I'm currently running a 255/35/20 and it rubs the fender liners when rides gets a little bumpy and tires look kinda bulky.
Old 12-24-06, 05:03 PM
Aristo300
Aristo300's Avatar
Ok, I'll answer the question. The advantage of going with the 255mm tire would be the extra rubbing. That being said... if you want to rub more, get a 255, if you want it to look better and rub less, go with the 245.
Old 12-31-06, 04:41 PM
mjr24
mjr24's Avatar
Went with 255, no rubbing. Rubbing depends on the car.....not the tire size.
Old 12-31-06, 07:43 PM
Neo
The One
Neo's Avatar
True. Rubbing will depend on the combination of rim spec, tire spec, offset, AND the car it is going on. You never specified what car it was going to go on. Maybe some just assumed.
RONSKI23
01-14-14 12:48 PM
SpaceCadet
01-24-13 06:37 AM
edub669
SC- 1st Gen (1992-2000)
06-17-10 07:01 PM
350nub
VIP Style
19
06-22-08 06:26 PM
02Ku
04-06-06 08:42 AM
Quick Reply: 20x9 rim in front....245/30/20 or 255/30/20
