HELP NEEDED! Will these tires fit?
Someone help me because i found a set of NEW tires for dirt cheap!
My rims are 20x8.5front/offset 45mm and 20x10 rear/offset 40mm. My car is a 2002 GS300. Would these tires be okay?
The tires are Goodyear Eagle F1 Supercar.
(2) 245/45ZR20
(2) 255/45ZR-20
Would this be okay on my wheels??? THANKS!!
And i have no plans to lower the car.
(2) 245/45ZR20
(2) 255/45ZR-20
(2) 245/45ZR20
(2) 255/45ZR-20
(2) 245/45ZR20
(2) 255/45ZR-20
Just noticed for the front I would do 245-35-20, the 45 sidewall would be huge
I can't believe some of the responses... NO THESE TIRES ARE NOT OK! If you want to buy the tires and sell them for a profit, then use the money to purchase PROPER sized tires, go for it. These tires are waaaay out of spec.
Don't just throw crap on your ride that doesn't belong there, even if it was free.
So the right tire would be.....
Front - 245/35/20
Rear - 275/30/20
Am i correct?
For a bit more information, go to http://www.lgwnorcal.com/articles/index.html#null and check out the wheel fitment guide. Should answer your questions and help you make some good choices about "cheap" tires. Good luck and post pics...
