Wheel Question For IS250
Will 19x9 offset 45 - 235/35/19 (front) and 19x10 offset 45 - 275/30/19 (rear) work for a IS250 RWD lowered on Eibach Pro Kit with no rubbing?
flipsonic,
based on those offsets, I'm guessing you changed your mind on the VS-XXs?
From what I've been seeing in the IS forum, aren't most guys having rubbing problems on the inner fender even with 8.5" +35 to +40 on the fronts? Are you sure you want to try to fit a 9"? From what others have been reporting, if you want to avoid rubbing, you'll have to go with 8" in the front. Any wider and you'll have to mod the inner fender liner and/or shave the fender lip.
flipsonic,
Someone told me a 45 offset to my 19x9 front wheels (on order) will have a larger lip than with a lower offset. Is this true? I thought it would've been the other way around. Can anyone comment?
masboy
09-28-07 12:42 PM
