Should I get 18s or 19s?? Please Help....
Old 11-26-06, 04:31 AM
2FiVE8
2FiVE8's Avatar
Smile Should I get 18s or 19s?? Please Help....
I am gonna be picking up a 2001 GS and i am debating whether to go with 18x8.5/18x9.5 or go with a 19 inch rim. I plan on dropping it with some TEIN SS and I am goin to be daily driving it. I like the look of 19s but the tires are $$$ do u guys think that the 18s will look too small???? Any feedback would be greatly appreciated......
Old 11-26-06, 04:37 AM
AJ
AJ's Avatar
I say 19's , much better look . of course , you can pull off 18's with no trouble . so it's all about preference .
Old 11-26-06, 05:58 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
I say go with 19"s
Old 11-26-06, 06:15 AM
GWELEX
GWELEX's Avatar
If done corrrectly, 19's will look great and there will be hardly any loss in ride quality. My 19's are +35 and 19x8 all the way around with 245x35 UHP Generals. I would of liked a little more offset on the rears, about 5mm, but I really wanted to go with the same size for tire rotations later on. The choice is all yours and I understand the rationalization of cash flow, 18's can look mighty fine too. Whatever you choose, try to match the overall diameter of stock as close as possible to keep things in sync, i.e. the speedo.
Old 11-26-06, 07:00 AM
LEXUS_KID
LEXUS_KID's Avatar
19=
Old 11-26-06, 12:00 PM
RA40
Super Moderator
RA40's Avatar
While I have 18's currently, 19's are that sweet spot.
Old 11-26-06, 05:17 PM
leestoy
leestoy's Avatar
Kick It Up A Notch = 20's.....
Old 11-26-06, 06:28 PM
GS FONZy
GS FONZy's Avatar
yes 20" i have them and i wish they looked bigger. 2" drop front 1.5" back
Old 11-26-06, 06:32 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,127 Likes on 1,297 Posts
This is a topic of a lot of discussion in the past here on CL, here are a few threads to get you started I found using search (suggest you try the search feature out as well)
Threads on 18's or 19's
https://www.clublexus.com/forums/sho...hlight=18s+19s
https://www.clublexus.com/forums/sho...hlight=19s+20s
Just in case...
Threads on 19s or 20s
Threads on 20's and ride quality
https://www.clublexus.com/forums/sho...light=20s+ride
Don't forget about rubbing as well for 20s and some 19s... not all experience it but some do.https://www.clublexus.com/forums/sho...light=20s+ride
Nice wheel guide
Chrome / Hi Polish
Polls in the voting booth
https://www.clublexus.com/forums/hall-of-fame-and-voting-booth/98821-did-you-would-you-upgrade-your-wheel-size-from-oem.html
https://www.clublexus.com/forums/sho...d.php?t=128050
17 or 18's just to be thorough
https://www.clublexus.com/forums/sho...d.php?t=162617
Hope this is helpful
Old 11-26-06, 06:40 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
BTW I've had both 18s and 19s... personally would go for a 'fat 19' setup for the best combination of looks and ride quality.
18s
19s
Old 11-26-06, 10:26 PM
girlilove
girlilove's Avatar
What is the ride quality between:
A) a dropped 245/40/18 & 275/35/18 (with barely a 1 finger gap front & rear)
B) a dropped 245/35/19 & 275/30/19 (with 1 finger gap front & rear)?
Which of the above options would contribute a more smoother ride?
Thanks in advance
Old 11-27-06, 04:19 PM
2FiVE8
2FiVE8's Avatar
Smile
thanks for all the helpful info, i like the 19s too but i found some work equips that are 18s so i think im gonna go with those ones, and since i dont plan on throwing any kit on i think i will be just fine...thanks dave too for all the helpful links..
Old 11-27-06, 04:49 PM
mparks
mparks's Avatar
19s all day every day! With a nice sized lip of course.
Are 19s to y'all what 22s are to Impalas like mine?
If so then it is purely a judgement call based on driving style and local roads.
I role conservative 20s because Michigan roads have potholes inside of potholes.
silent1pro
SC- 1st Gen (1992-2000)
20
03-25-07 08:07 PM
mvallido
10-13-06 10:44 PM
chaskim
01-21-05 01:19 AM
Ag02M5
04-14-03 07:28 PM
GSPOWER
05-19-01 06:50 AM
Quick Reply: Should I get 18s or 19s?? Please Help....
