Lexus TPMS ***Important***
Old 11-07-06, 01:21 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default Lexus TPMS ***Important***
Lexus
An Update on Tire Pressure Monitoring Systems and Aftermarket Wheels
A direct tire pressure monitoring systems (TPMS) will be standard equipment on every vehicle sold in the U.S. after September, 2007. The criteria for TPMS standardization is that the vehicle must have only four wheels (no dual-wheeled trucks or motorcycles), and weigh less than 10,000 lbs.
All new 2007 Lexus vehicles have a direct valve sensor TPMS (see TPMS Facts below) but the older LS-series used the indirect system. Lexus currently uses Pacific sensors (carried by The Tire Rack) for all direct system-equipped Lexus vehicles up to the 2006 model year. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, the sensor will not fit properly. Wheel manufacturers are aware of the issue and are rushing to get most of their wheels TPMS-compatible.
The Tire Rack's fitment specialists have carefully determined which wheels that are currently available will be compatible with the system installed on your vehicle.
If you have any questions about the wheel you're considering, call or post your question for confirmation that it will be compatible with your TPMS.
TPMS Facts
Direct TPMS use a sensor in the wheel/tire to wirelessly relay pressure back to the driver via a display inside the vehicle. Some vehicles have a digital screen that continuously shows all four tire pressures (five if spare has sensor). Others simply flash a "low tire pressure" light on the dash. Additionally, there are two different styles of sensors for a direct system: a valve sensor and a strap/band sensor. Only valve sensors are used on Lexus direct system-equipped vehicles. If you bought an aftermarket SmarTire TPMS, its sensors are held on by a strap around the barrel of the wheel.
Indirect systems work in conjunction with the ABS wheel speed sensors that “count” the number of revolutions of each tire. If the right front tire is low (25psi) it will spin faster than the left front tire (35psi). The ABS system will recognize this change and alert the driver with a flashing light and possibly a loud chime. The Lexus LS's indirect system does not affect the fitment of aftermarket wheels.
Brandon@TR is offline
Old 04-21-07, 01:40 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
TPMS works up to 2007 now.
Old 02-07-08, 03:05 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Feb. 7th 2008 Update:
Lexus
Tire pressure monitoring systems (TPMS) are now impossible to run from when buying a new vehicle. Every new vehicle made for sale in the USA has a direct TPM system as standard equipment. There are several exceptions though: the vehicle must have only four wheels (so no dual-wheeled trucks or motorcycles), and the GVWR must be less than 10,000lbs.
We carry every sensor for every Lexus model up to the 2008 model year.
The basics of the direct TPMS is that it uses a sensor in the wheel/tire to wirelessly relay pressure back to the driver on some sort of display. Some vehicles have a digital info screen that will show all four tire pressures (five pressures if spare has sensor) all the time. While others might just flash a low-tire-pressure light on the dash. There are also two different styles of sensors for this system: a valve sensor and a strap/band sensor. Only valve sensors are used by the direct system-equipped Lexus’s, although if you bought an aftermarket SmarTire TPM system, those use the sensors held on by a strap around the barrel of the wheel.
The Lexus LS’s and RX’s indirect system will not affect the choice of switching aftermarket wheels or tires. The system runs off of the ABS/wheel-speed sensors which “count” the number of revolutions of each tire. If the right-front tire is low (25psi) it will spin faster than the left-front tire (35psi), so the ABS system will recognize this change and alert the driver with a flashing light near the gauge cluster and possibly a loud chime.
Lexus currently uses several different protocalled sensors from just one company: Pacific Industries. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, then obviously the sensor will not fit properly. The wheel industries are aware of the valve sensors and are rushing to get most of their wheels TPMS-compatible. If you have any questions about the TPMS-fitment on a wheel that The Tire Rack sells, I can look up the wheel and confirm if it will work with your vehicle.
Carista
10-31-18 10:32 AM
Parsa
07-07-16 01:11 PM
Ne1tHeRe
RC F (2015-present)
04-01-16 08:00 AM
mattds
03-02-16 12:05 PM
girvan
07-31-09 09:34 PM
Quick Reply: Lexus TPMS ***Important***
