Need Help!! 19x10.5in Rim will 275/35r19's fit without rubbing?
Old 09-22-06, 05:19 PM
JAYGS4NYC
JAYGS4NYC's Avatar
Default Need Help!! 19x10.5in Rim will 275/35r19's fit without rubbing?
I need to buy two new tires for the rear. I am currently runnin 265/30r19 in the rear but i want somethin with a fatter sidewall for these damn NYC streets. I was wondering if 275/35r19 Toyo Proxes t1-r tires(to match the front) fit without rubbing or modification? The wheels are Lowenhart LD1's 19x10.5 rear and 19x9.5 front with 245/35/19s.Thanks to everyone in advance...
Old 09-22-06, 06:49 PM
nysupraman
nysupraman's Avatar
im running 10s out back with 275 35s, but i guess rubbing depends on your height and camber and offset? im 2inches lower, camber kit, and +38 out back. i am also shaved hope that helps a bit. and i understand where your comin from, i live on LI but drive in the city everyday!i guess you wouldnt rub on stock height with a higher offset and no camber kit.
Randre19
Suspension and Brakes
20
09-26-20 12:37 PM
jackdahou
12-05-16 08:53 PM
Ltaboso
IS F (2008-2014)
11-02-15 04:58 PM
corkycal
IS F (2008-2014)
14
10-10-10 03:48 PM
Socal300sd
07-20-09 04:38 PM
Quick Reply: Need Help!! 19x10.5in Rim will 275/35r19's fit without rubbing?
