Will these fit?? 93' LS400
Old 09-19-06, 09:45 AM
AZDesertGS
AZDesertGS's Avatar
Default Will these fit?? 93' LS400
I know with the earlier LS400...wheels that clear the calipers are the big question. These knock-offs on ebay look nice so I was wondering what people thought of these and do you think they will fit?? They say they do in the ad but we all know how that goes.
Description: 4 new 18 x 7.5" New Silver Sport Lexus LS-430 Wheels
Questions: Toll free 1 866 273 3651 8:00 am to 6:00 pm, EST Monday thru Friday
Fits: ES300 92-03 / ES330 04-05 / GS300 93-03 / GS400 98-00 / GS430 01-03 / IS300 01-05 / LS400 90-02
/ LS430 01-05 / SC SERIES 92-05 / If you have questions on fitment just give us a call toll free. 1 866 273 3651
Wheels: 18 x 7.5" These wheels are manufactured in a original equipment plant to original specification. They are DOT, JWL, VIA and TUV approved. They are side impact and load bearing tested. They are manufactured with the highest quality A-365.2 virgin aluminum. The finish is superior and we are the manufacture.
Finish: Silver. They are a powder coat, clear coat finish and not a one stage enamel. This is the correct way to finish a wheel. They have an absolutely beautiful finish with a superior sheen that is noticeable in the photos.
Old 09-20-06, 05:22 PM
trukn1
NELOC Mod
trukn1's Avatar
18x7.5 (sizewise) will fit with no problem. I am currently running the same size. The most important thing you need to find out is the center bore of the rim. Just want to make sure they are hubcentric, if not you will need hubcentric rings. Also you need to find out what the offset of the rims are as well as make sure they will fit over the studs.
With a 93, I think it is the same as my 92.
Hub diameter- 60.1mm
bolt pattern- 5x114.3
lugnut- 12mmx1.5
As long as the bolt pattern and lugnut dimensions are the exact same then you can fit them, The hub dimension can be different , like i mentioned before, however if it is not an exact match then the rim is not huncentric and you will need to get hubcentric rings.
This is for another site, but it will help you to determine fitment as a guide...
http://www.topswheel.com/fittingcheck.htm
dukeyukey
15
04-04-13 05:40 AM
shagadelic
04-24-11 10:55 PM
stoked
01-21-09 09:36 PM
MacLS430KS
07-26-08 01:59 PM
ptkelly
04-15-05 02:12 PM
Quick Reply: Will these fit?? 93' LS400
