Can I get wider tires?
Old 09-06-06, 04:31 AM
XSTeknique
XSTeknique's Avatar
Default Can I get wider tires?
Hey guys, I have 245/35/19 tires stretched on my rears and it's time to replace them. Right now I have maybe an inch between the fender and the tire. My question is, if I removed the plastic piece on the rim of the fender, do you think I could fit a wider tire (like 275/30/19) without fender work. I'm tired of the stretched tire look. Thanks ahead for your input guys!
Old 09-06-06, 06:00 AM
Hai_Nguyen
Hai_Nguyen's Avatar
I think you'd be cutting it pretty close. If it does just do a minor shave or pull.
Old 09-06-06, 06:03 AM
Rising_Sun
Rising_Sun's Avatar
What are the specs on your wheels? I have 285/30/19s on the back of my car with a mild roll of the fender (louieville slugger)
Old 09-06-06, 06:04 AM
RGW LLC
Former Sponsor
RGW LLC's Avatar
it's all about the off-set on your wheels....all my SC has 19x10 on the back, and got 275/30/19 tires on them.....i didn't have to remove any trim or roll any part of the rear fender....NOTHING....everything bolts right on and clear everything....and perfect flush even......
so you gotta find out what's your offset, i have 38+ off-set for the rear on all my cars....
Old 09-06-06, 06:57 AM
BiZ
BiZ's Avatar
Offset does play a part, but the suspension setup is also a determining factor. I have 285/40/17s on the rear and I just put on some Tein Flex coilovers. Before with the stock suspension there was no chance that it would rub. Now with the coilovers if I go any lower than what they are currently set at it will rub.
Old 09-06-06, 07:27 AM
XSTeknique
XSTeknique's Avatar
I don't have a very aggressive offset on the back, but combined with my Espelir springs you can only fit my Lexus key vertically between the tire and the fender. That's exactly how much room there is right now. I'm just deciding whether to go with the same size tire or not. It's looking like I'm stuck. Guess I'd save myself a few bucks by stretching again.
Old 09-06-06, 07:35 AM
Rising_Sun
Rising_Sun's Avatar
My offsets are a bit aggressive +30 19x10 and I dont have any rubbing issues with my Supra Eibach set-up
Old 09-11-06, 11:36 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
19x9.5 with 35 offset and 275/30-19 and the fenders rolled - there's about 3 mm clearance from tire to fender with suspension compressed...
dannyboy26
12-28-13 08:17 PM
es3doubleO
07-18-11 05:42 AM
heocon
01-27-08 08:14 PM
masboy
09-28-07 12:42 PM
GSoup
NELOC
11-28-06 07:18 PM
Quick Reply: Can I get wider tires?
