20" Wheel fitment help needed on an LS430
Old 08-15-06, 07:52 PM
Blue98Gs3
Blue98Gs3's Avatar
Default 20" Wheel fitment help needed on an LS430
Hows it going guys, I need some insight. A guy wants to pick up my 20" Giovana Attack 2's and he has an LS430. I'm sure they'll fit size wise, but I'm worried about the brake caliper up front.
To clear a TT brake set up with these wheels on a GS you need a 7.5mm spacer.
Would you need a spacer on the LS?
any insight would be very nice.
Thanks
Old 08-15-06, 11:01 PM
rominl
exclusive matchup
rominl's Avatar
yes you need spacers. the calipers on the ls430 are big just like the tt
Old 08-16-06, 10:46 AM
Blue98Gs3
Blue98Gs3's Avatar
Are they just as big as the TT's? Basically you will need a 10mm spacer for them as well. With a 10mm spacer what wil the relationship to the fender be like?
Old 08-16-06, 11:02 PM
rominl
exclusive matchup
rominl's Avatar
i think if 10mm clears the tt, it will probably clear the ls430 brakes as well. just a guess here of course
and that means the wheels would be 10mm closer to fender?
Old 08-17-06, 08:27 AM
Blue98Gs3
Blue98Gs3's Avatar
Thats correct. So how would a 8.5 inch wheel with a 35mm offset and 10mm spacer set up on an LS?
Old 08-19-06, 07:00 PM
jpcdmd
jpcdmd's Avatar
Sucks.
I had a set of Kaotiks that were 20x8.5, 35 offset, and I only needed a 3mm spacer to clear the caliper. Depends on the spoke design. I had terrible steering feel and kickback in the wheel, made driving the car not enjoyable. I didn't have any vibration because I used the appropriate size hubcentric rings, but the net 32mm offset just plain sucked. It looks even worse because the rear wheel (I'm assuming these are NOT staggered) is tucked way under but the friont sticks way out with the spacer. I can't imagine how crappy it would look with a 10mm spacer.
Old 08-23-06, 05:56 PM
bluelex
bluelex's Avatar
He hit it right on the noce, your going to come across the issue of looks where the front wheels are going to look flush but the rears are going to be sucked it. Unless he does 10mm spacer all around to correct this.
Old 08-23-06, 08:21 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
Originally Posted by jpcdmd
Sucks. It looks even worse because the rear wheel (I'm assuming these are NOT staggered) is tucked way under but the friont sticks way out with the spacer. I can't imagine how crappy it would look with a 10mm spacer.
You are absolutely correct there, I have seen cars with huge spacers up front and non staggered wheels, it almost looks like the car is driving backwards!
maynanator
Suspension and Brakes
10-08-12 09:57 PM
TylerNol
06-14-12 12:15 PM
FormosaSC
18
01-13-11 05:06 PM
oteck
07-14-10 12:02 PM
playa3uhh
05-31-06 09:23 AM
Quick Reply: 20" Wheel fitment help needed on an LS430
