factory wheels with spacers.
I'm not sure of the factory offset so I wouldn't be able to tell you, but you might want to also take into consideration that the wheels would no longer be hubcentrice and would cause vibrations.. Also, yo most likely will have to change out your studs to longer ones to accomodate since yo won't barely get enough turns on the lug nuts...
exclusive matchup
Originally Posted by Neo
Front spacing aside, will the caliper and rotor even fit in the 16s? I don't recall anyone trying this so you might have to be the guinea pig.
the supra tt rotors are 12.7". so if 13.5" is max for 17s, that means at most 12.5" rotors for the 16s?
imho it's way too risky
keep in mind, this has nothing to do with spacers anymore. we are talking about the overall circumference clearence
ifilrx
Suspension and Brakes
17
05-04-07 08:37 PM
