This Offset on my GS... Will it work (F) 27mm (R) 37mm
Old 07-19-06, 09:18 PM
j stuff
j stuff's Avatar
Default This Offset on my GS... Will it work (F) 27mm (R) 37mm
19x9 front 19x10 rear
(F) 27mm (R) 37mm
Wondering how this would look and if it would work
Old 07-19-06, 09:54 PM
rominl
exclusive matchup
rominl's Avatar
the front is pretty aggressive, if you really want to fit, roll the fender and put on stretched tires
the rear is aggressive but it's ok, as long as you shave the fenders
Old 07-19-06, 10:38 PM
SSK0771
SSK0771's Avatar
+1
19x9 +27 is pretty aggressive for GS
Old 07-20-06, 12:02 AM
j stuff
j stuff's Avatar
Thanks for your input guys, i have no problem with rolling fenders or stretching tires a tad
Im tryin to find anyone with similar offset to see what it looks like
Old 07-20-06, 07:13 AM
BUSTN
BUSTN's Avatar
Here is a pic of 20x8.5 +20 225/35r20 on my gs.It's almost the same with a 9 +27.No neg. camber has been added this is just from the drop of the car.It does not rub and I can turn lock to lock.Hope this helps.
Old 07-20-06, 08:27 AM
j stuff
j stuff's Avatar
Thanks for the pic! If anyone else has any thing that can help out its much appreciated.
Old 07-20-06, 08:39 AM
j stuff
j stuff's Avatar
Hmm this is gettin really confusing now
Someone on vipstylecars.com said
"it depends on the width of the wheel...but the rear is pretty weak...if the rim anywhere between 9-10" wide, you want to have the offset in low +20's. I don't remember what it should have for the front...I think it's somewhere near +25~30 for a 9" wide wheel"
Old 07-20-06, 08:46 AM
05EX
05EX's Avatar
BUSTN do you have any side pics of your car?
Old 07-20-06, 08:55 AM
rominl
exclusive matchup
rominl's Avatar
that's because you were on vipstylecars.com
look at my gallery on pics of my 10.5 +41, which is same as 10 +35 with 285/30/20
keep in mind i have michelin tires that's why the tires are more meaty then others.
but you can see how close i am to the fender, and i shaved everything already. and imagine 15mm more sticking out, that's what you will get if you get 10 +20. it's your call. for sure you will have to run stretch tires, and the wheels will be past the fenders imho
bottom line is, what's your definition of fit. how far do you want to go on your car to make them fit? how stretch do you want to run your tires (which also means careful choice of tire brand and model)? what alignment settings you want to go with? do you want the wheel itself to get past the fender?
we have had discussions on these for way too long already, i don't think there is absolute answer for anyone. the above questions will determine everyone's preference already. all i can tell you is, i know my limit and with my setup i can still rub BOTH front and back if i hit bad deep. so personally i don't see myself running much more aggressive setup. what others do, they have their priorities
Old 07-20-06, 09:33 AM
GATO
GATO's Avatar
J stuff, here is a pic of mr. aristo GS. ( hope he doesn't mind me posting his pic )
specs are
fronts - 19x9 +24 (245/35-19)
rears - 19x10 +29 (275/30-19)
yours would be 3mm in. wich isn't much.
but in my opinion, this set looks awesome
Old 07-20-06, 09:40 AM
j stuff
j stuff's Avatar
Thanks for the detailed reply, i like the way yours is. If i decide to go further out perhaps i could get spacers in the future but right now that looks good to me.
Old 07-20-06, 10:58 AM
j stuff
j stuff's Avatar
I have the worst luck. These wheels are now sold. Thanks for all the help thus far rominl i have learned a lot about offsets in just two days from you guys.
Old 07-20-06, 01:44 PM
BUSTN
BUSTN's Avatar
Here is a pic of gt-7's in 9.5 +24 on the rear.To me it was weak.I am now running a 10 +27 (which is the same offset...)and I am looking to go a lil more.
Old 07-20-06, 01:46 PM
BUSTN
BUSTN's Avatar
here is a 10 +27 from the rear.Notice their still plenty of space left.If I were to run a 265 on the rear it would look better.Its a 245 on there now.
Old 07-20-06, 01:57 PM
j stuff
j stuff's Avatar
i like that last pic, man im looking at some wheels that are +12 in the rear, i duno if i can pull that off.
Max16
IS F (2008-2014)
11-24-16 08:06 AM
corkycal
IS F (2008-2014)
14
10-10-10 03:48 PM
Jpn_kid
SC- 1st Gen (1992-2000)
08-08-08 03:28 PM
TTurboPimp
Suspension and Brakes
15
06-06-08 07:03 PM
1SWTGS
12-09-07 09:34 PM
Quick Reply: This Offset on my GS... Will it work (F) 27mm (R) 37mm
