Fittament question
Old 07-08-06, 01:03 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Default Fittament question
Will thiss size fit the ISx50 19X10+29 19X11+35?
Old 07-08-06, 01:05 AM
rominl
exclusive matchup
rominl's Avatar
on is250? personally i highly highly doubt it
Old 07-09-06, 11:10 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
So i guess it wont fit then. THnaks
Old 07-10-06, 10:00 AM
IS_250
IS_250's Avatar
after being under my IS a few times i think its safe to say no... but i have seen some crazy offsets on a GS by stretching tires and pulling the fenders.
Old 07-10-06, 06:19 PM
SoCalSC4
SoCalSC4's Avatar
I like my wheels aggressive, but those are a bit much for the IS. Are you willing to modify the car?
It sounds like you are going for a serious VIP look.
That set-up is:
Front: 28mm more aggressive (further out) than a "normal" IS fitment - probably 12mm past the fender
Rear: 21mm more aggressive (further out) than a "normal" IS fitment - probably about 10mm past the fender
I wouldn't say it's impossible, but you'll need to stretch the tires and crank the camber in (negative). I haven't seen the IS suspension in person, but if it's like the new GS, there is NO camber adjustment from the factory. The camber could be adjusted with custom made suspension components, though. It's all about time & money!
Old 07-11-06, 12:42 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
I jsut want a fat lip on the reears. I know those sizes are too extreme. What size do you guys suggest in 19s with a fat lip on the rearS?
Old 07-12-06, 02:51 PM
IS_250
IS_250's Avatar
i suggest going with something custom like HRE, DPE, Iforged or Asanti if you are looking for the deepest lip. Volk and Work have a decent selection of offsets and widths, but usually there will be some limits on the lip sizes.
Old 07-12-06, 10:18 PM
rominl
exclusive matchup
rominl's Avatar
well actually it depends on the wheel brands i guess. for example with some wheels you can get about the same size as say hre. that's the case for some trafficstar. it's all about the spoke design
Old 07-13-06, 12:41 AM
flyfl1pguy
Registered User
flyfl1pguy's Avatar
Im in the market for a mesh type wheels. GT-U only makes 18s but Im starting to like the GT-Ms. . .
Zoolander
08-04-15 02:01 PM
LionelHutz
IS F (2008-2014)
12-15-13 09:25 PM
Hypebeast
12-09-11 07:01 AM
allst4r
12-06-11 07:30 PM
Quick Reply: Fittament question
