tire fitment on 1gen gs
Old 07-07-06, 12:23 PM
GoldGS3
GoldGS3's Avatar
Question tire fitment on 1gen gs
could i use 255/50/16 tire wrapped on 16X8 with +50 offset on 1gen gs front axel?
thank you.
Old 07-07-06, 12:26 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Default ...
16 x 8 +50 sounds like an OEM wheel. The tire you mentioned above is too wide and if you were to mount it on that wheel it would bubble out on the sides. You're better off going with a 215 or a 225 .
Old 07-07-06, 12:41 PM
GoldGS3
GoldGS3's Avatar
Thanks Seize.
How about 245/50/16?
Old 07-07-06, 12:51 PM
Seize
Seize's Avatar
Default ...
Originally Posted by GoldGS3
Thanks Seize.
It would fit, the 245 is geared more toward an 8.5" wheel but it wouldn't bubble out as much as a 255.
Oh and by the way, 225/235 is the most I'd go on an 8" wheel but that's just me
Old 07-07-06, 01:01 PM
SoCalSC4
SoCalSC4's Avatar
On my brother's first-gen, I temporarily installed my stock 17x8 +50 GS 400 wheels with 235/45-17 tires. The wheels had the old-school clip-on weights on the inside of the wheel lip. The weights hung over the run enough to contact the suspension upright, causing a "knock-knock-knock" noise from the front of the car. As a temporary fix, I removed the wheel weights.
I think if you go larger than 235/45-17 on that 16x8 +50 you may actually have an issue with the tire hitting the front suspension, due to the way the sidewalls 'bulge' over the rim. A scary prospect. Lower offset wheels would look much better on the first-gen. 8" +50 looks absolutely LOST on the car.
t78rx8
06-02-14 02:39 PM
ewingli
SC- 1st Gen (1992-2000)
05-18-12 07:15 AM
LTU-Lexus
08-22-09 08:11 PM
ksoazn
Wheels and Tires Classifieds
11-06-06 10:25 AM
Quick Reply: tire fitment on 1gen gs
